weird throttle issue. Help, I need some opinions.
Old Oct 20, 2009 | 03:12 PM
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
Default weird throttle issue. Help, I need some opinions.
Hey fellas
Well the past week or so... the Z has been the bain of my existence lol. Iam having some sort of throttle issue . I CANT figure it out!!! so here Iam.
the problem:
Well the car starts and idles perfectly fine, just like a new car. I can take it out It drives perfectly fine as well ( normal driving ).. BUT... ( it doesnt matter what gear iam in ) when I go WOT.. it just doesnt go anywhere?.. I have absolutely no throttle response .. It doesn't " bug " or anything.. I can be at 50mph.. go WOT.. and it just doesnt pick up, doesnt go anywhere whats so ever.
What Ive one :
I cleaned the MAF
I cleaned the Throttle body
I replaced/swapped the MAF
I replaced/swapped the Throttle body
Swapped the stock air box
Removed battery
Re-set the ECU
Re-set the throttle position learning
Re-set idle/air
NO CEL
Iam out of options ... any ideas? b4 nissan rips me off??
Thanks!!
Old Oct 20, 2009 | 04:55 PM
aaronz8's Avatar
aaronz8
good luck!
Old Oct 20, 2009 | 05:06 PM
crg914's Avatar
crg914
Is there any way you could use a scan tool to make a recording while you duplicate this problem and post the values?
If you rev it in neutral does the engine respond as it should?
Old Oct 20, 2009 | 06:37 PM
Vas@Extended
what kind of scan tool?? ^
it revs fine.. in the low rps.. and throttle response is sharp.. but if i try n rev it to liek 5-7k.. it goes there ( no hesitations ) but just like kinda slow... b4 it used to jump to redline like a bat outta hell.
Old Oct 20, 2009 | 06:40 PM
crg914's Avatar
crg914
Any kind of scan tool that has the capability to record would suffice. Some parameters that would be good to monitor would be RPM, Load, O2 sensors, Throttle %/Throttle angle, Timing advance, MAF, fuel trims, etc.
Are you on the stock ECU or using a stand alone?
Old Oct 20, 2009 | 06:43 PM
Vas@Extended
stock ECU... I used to have vortech ( see sig ).. and did run a utec.. but everything is put to stock now.. and then .. this problem..
Old Oct 21, 2009 | 02:52 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Can you find someone who has the newer Snapon Verus scan tool.We just got it a month ago and it has incredible capabilites.
Old Oct 21, 2009 | 09:49 PM
GIANNI's Avatar
GIANNI
wow i have the samething going on with mine
Old Oct 22, 2009 | 06:13 AM
Vas@Extended
nope =(.. that name is really new to me... Ill do a search on it... is it a lot of $$$?
car is at nissan now.. so we will see what they say...
Old Oct 22, 2009 | 06:15 AM
Vas@Extended
HAHA nvm.. it costs 8999$ =o...
Old Oct 24, 2009 | 09:17 AM
Vas@Extended
BUMP for help
Well nissan couldnt find the problem and they said i need to put the stock exhaust back on? like wtf?...
Iam going to take the plenum out again and put the stock fuel pump back on and see
Old Nov 11, 2009 | 05:24 AM
deckdout2's Avatar
deckdout2
That's so clearly symptoms of the MAF, but then again you cleaned/swapped that already. I don't know bro, either fuel or fire relate obviously. Have you swapped plugs, checked the coils, checked the fuel pump?
-Paramy
Old Nov 11, 2009 | 08:32 AM
djamps's Avatar
djamps
No CEL? Wow... my guess would be TP sensor or incorrectly learning in the pedal dance. One time I did the pedal dance incorrectly and the car ran just like that... like 1/4 throttle was all I could get when it was floored.
Uriyo_
Sep 8, 2021 08:46 AM
pslamp32
Feb 8, 2017 09:07 AM
350z82
Oct 1, 2015 06:25 PM
