GTM Valvebody Upgrade Issue?(car towed)
Old Oct 24, 2009 | 02:09 PM
A.H's Avatar
A.H
Unhappy GTM Valvebody Upgrade Issue?(car towed)
Well i was driving from San Diego to LA for the weekend and as I was 20 miles away from LA, the car could no longer put power to the wheels. It felt like the clutch was slipping, and i couldn't do anything. At first, it only slipped a little but after 5 more miles of driving(note this is on the 5 freeway during rush hour on a Friday) it was just revving when i was in gear(keep in mind it's a 5AT). So i luckily got off the freeway and with the help of some nice people pushed it into a Carls Jr. parking lot until i waited for the tow. Took 4 guys and about an hour to just get my car on the flatbed because i'ts low and then I had it towed to Precision Z even though they are closed until Monday(it's located right by my house so it didn't cost extra).
My car has about 23k miles on it and the only thing I've modified reguarding the transmission is the valvebody and that's my guess at what my problem is. Now idk what i'm going to do because GTM is 100 miles away, and I still don't know what exactly the problem is. The valvebody was installed at GTM just for reference. I loved every second of the upgrade until this failure. I really hope I can get the car up and running soon. Any thoughts on the matter would be appreciated.
-Arsh
Old Oct 24, 2009 | 04:01 PM
Resmarted's Avatar
Resmarted
Interesting. Sounds almost like you developed a tranny fluid leak sometime or maybe a gasket wasn't fully sealed and the higher pressure of driving for 5 hours broke the gasket. Did you notice any fluids?
Either that or maybe a solenoid went bad?
In for response! GL man!
EDIT:
Specifically I would look at the torque converter solenoid, and the pressure control solenoid. These two are responsible for the clutch/torque converter...
If your pressure control solenoid is weak it could cause your clutches to slip like gnar, then after driving a while the clutches would go completely bad and just slip....
the torque converter solenoid (if it goes bad) would keep the tq conv from sending any power to the rear....
You should def get a tranny cooler any way this goes.
again gl man.
Old Oct 24, 2009 | 05:47 PM
A.H's Avatar
A.H
Yea I checked for leaking fluids and there were none. Such a wierd problem. Never heard of this happening to anyone else so we'll wait and see what the problem really is once i can get precision to take a look at it. I'm hoping for the best right now and i know i need that tranny cooler but i've been really tight on cash lately.
Old Oct 24, 2009 | 10:40 PM
350Zdj's Avatar
350Zdj
same thing happened to mine but the cause was horrific. There was a hole somewhere in my radiator which caused the ATF and Engine Coolant to mix together. The fluid cocktail then made it to the tranny and caused havoc - 1st to 4th the Z was screaming like hell but it was moving inch by inch lol. So yea, check the colors of your fluid - if it turned something like vanilla brown then it's bad news. hopefully not.
After i got everything fixed my gear started to lightly slip when going from 3rd to 4th. . .
fyi my tranny is stock xcept for the oil cooler which i just recently installed
Old Oct 25, 2009 | 11:20 AM
Adrians07Z's Avatar
Adrians07Z
damn ..
and I was just about to buy the kit today .. might still do it if I get a pm back from the guy
curious to see what the problem is ..
EDIT - doesn't GTM claim to mess with the solenoids when they install the kit? .. maybe its something they messed with
Old Oct 26, 2009 | 06:41 PM
A.H's Avatar
A.H
Here's is a short update because I'm on my phone.
Transmission=toast/fried/shot/dead at 23k miles on a 07....
Old Oct 26, 2009 | 07:00 PM
Waiz's Avatar
Waiz
^Damn dude sorry to hear.
Let us know what happened when you can.
Old Oct 26, 2009 | 07:02 PM
Sergio07350Z's Avatar
Sergio07350Z
Noooo!!!
Old Oct 26, 2009 | 07:23 PM
ford_jj's Avatar
ford_jj
Default Good luck
Have you been resolved your problem?
Old Oct 26, 2009 | 07:24 PM
ford_jj's Avatar
ford_jj
Default Good luck
Old Oct 27, 2009 | 04:15 AM
Adrians07Z's Avatar
Adrians07Z
WARRANTY !!!
could atleast try it since the valvebody is just a set of springs inside it .. dont think the dealer would dig that far and they would just replace the tranny
then all you loose is the valvebody upgrade which should be alot less than the price of a new tranny
Old Oct 27, 2009 | 09:10 AM
rcdash's Avatar
rcdash
Low fluid and heat kills the 5AT - that is all. Did you check ATF level after you got the car back from the upgrade? The dipstick will be dry being just 2 qts low, and that will kill the trans. Been there. Done that.
Old Oct 29, 2009 | 04:10 PM
Adrians07Z's Avatar
Adrians07Z
any updates
I'm about to install the transgo kit .. looking for fluid right now that is readily available (not dealer), but keep finding that you "have" to run J Matic from nissan or it could kill the tranny and it voids warranty
any idea what brand / kind of ATF that GTM used after the install?
Old Oct 29, 2009 | 04:16 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Its now called s matic and def stay with whats recommended.I know its expensive fluid but i wouldnt chance it by using something else.
Old Oct 29, 2009 | 04:30 PM
Adrians07Z's Avatar
Adrians07Z
yea .. I've been searching around
orielly auto parts don't recommend anything but OEM / Nissan
and everyone online says use s matic (j matic) from nissan .. theres the occasional "I use royal purple, amsoil, or castrol" ... but then found somewhere that said the castrol "j matic compatible" fluid overheats in the 350z ..
so a trip the dealer it is for me (royal purple was going to be my choice, but mixing it with oem and $12 / quart .. might as well go oem)
Old Nov 3, 2009 | 11:25 AM
A.H's Avatar
A.H
Ok guys, here is an update, sorry i haven't been on lately.
I tried to get it the warranty on it honored and i had the car towed to Valencia Nissan. They said over the phone they would do it and i told them all of my mods, but when i took it there they said they wouldn't touch it because "i had headers". Yea......wtf headers has to do with the transmission idk but i had it towed back to Precision and now Performance Nissan said they will take care of it 100% so i'm hopeful that they will come through for me. It's getting towed there today so i will update on how that goes. Now, we still don't know the exact reasoning of the transmission giving out. It might be due to the reason RCDASH suggested but we still don't know. I didn't think I would hve to check levels becasue GTM was doing the labor and they have probably the best rep out there. Now if I can get tranny replaced GTM said they would put in a new Valvebody for free but I don't even know if i want them to do that. I do not want any other problems with my car and just want to finally enjoy it without it being in a shop 2 weeks out of every month. I'm just scared if it was the valvebody that caused it and if it'll happen again wiht this new tranny 20k+ miles down the line, because I know for a fact I won't be able to get it warrantied a second time.
Old Nov 3, 2009 | 11:50 AM
Adrians07Z's Avatar
Adrians07Z
I don't know about the shift kit doing it .. how many cars on here have the kit, and how many have failed with the kit
I'd bet it has to do with the fluid level / and or heat .. maybe GTM topped it off .. looked good
then 200 miles down the road all the air worked out of the valve body and you ended up low
also why did GTM say they would put it in for free b/c your tranny failed .. do they know something was up with their install, or just helping you out
that reminds me .. I need to check my tranny fluid level .. its been a few hundred miles since I put the shift kit in
Old Nov 3, 2009 | 01:34 PM
fabre80's Avatar
fabre80
Am pretty sure it was the tranny fluid, I had some issues at first but it was because i did not have the right amount inside. I had to put like 5 1/2 quarts of the S matic fluid on my car after the VBU was done and now i had no issues since.
Old Nov 3, 2009 | 03:13 PM
superchargedg
Damn Noobs
When i originally did mine i had the fluid read right in the middle of the dip stick .....well a couple days later it started to slip and i had to add 1 and 1/2 more quarts to it.The trans has been fine since and this was over 1@1/2 YEARS AGO.
Old Nov 3, 2009 | 03:17 PM
Adrians07Z's Avatar
Adrians07Z
ok this is what I was thinking about before I installed mine ..
5 or so quarts .. your about 2.x too short
I measured every drop that drained out during the install .. came to about 7 quarts .. I added just over 7 quarts .. so I should be good
would make sense if you dont measure .. add till it reads .. then all the air works out of the vb over the next couple days and end up adding 1.5 quarts
