swaped a non rev for a REV UP now problems... help!
Old Nov 1, 2009 | 09:10 PM
G35-31's Avatar
G35-31
Default swaped a non rev for a REV UP now problems... help!
i just swaped my non rev motor for the REV UP motor and now my idle when i start up jumps by its self to 2k and then goes down between 1k - 1200 when i get on it car feels like theres something holding it back but i get the same thing, power while crusing it stutters i can get off the gas and the idle will stay there at rpm's,ive done the relearn prcedures and i have tried to reset the ecu by having it unpluged for over 15 hours but still same thing, im not throwing a (CEL) so i dont know what the hells going on , can anyone shoot me some advise?
Old Nov 1, 2009 | 10:05 PM
*Boose*'s Avatar
*Boose*
Sounds like vacuum line loose or disconnected.
Old Nov 2, 2009 | 05:52 AM
G35-31's Avatar
G35-31
But I can't hear any hissing sounds wouldn't a strong vac leak cause this?
Old Nov 2, 2009 | 05:57 AM
INTIMAZY's Avatar
INTIMAZY
You have a leak.
Old Nov 2, 2009 | 06:09 AM
zownz's Avatar
zownz
When you do this swap, do use a rev up ecu or your old one?
Old Nov 2, 2009 | 08:19 AM
G35-31's Avatar
G35-31
I Have the rev up ecu
Old Nov 2, 2009 | 02:09 PM
G35-31's Avatar
G35-31
ok so i gave in and went to the dealer, the scan tool they used didnt even register the ecu , so they told me the ecu is no good this is why when i did the relearn procedures this didnt work..
Old Nov 3, 2009 | 07:36 PM
Cide's Avatar
Cide
did u get all the of the wiring required to do it. such as main harness, and engine harness if u dont u may have a CAN problem. and ur ecm might not be getting all the signals it needs.
Old Nov 4, 2009 | 07:36 PM
exZilaration's Avatar
exZilaration
If they didn't register the ECU then that could be the main problem right there.
Did you use your old harness or the harness that came with your rev-up?
Old Nov 4, 2009 | 08:44 PM
G35-31's Avatar
G35-31
no i used the harness that came with the ecu
Old Nov 4, 2009 | 08:50 PM
G35-31's Avatar
G35-31
and what you mean register the ecu?
Old Nov 4, 2009 | 08:54 PM
dkmura's Avatar
dkmura
General & DIY Moderator
The problem with swapping different versions of the VQ is the wiring is quite different. The ECM may even snap into place with the main harness, yet not be communicating with the BCM, ABS and other sensors. I'll bet even the OBD II post (that CONSULT plugs into) isn't wired in a way that allows the ECM to respond.
You might try to decipher the wiring of both harnesses to rewire them properly. You can find some of the diagrams in the FSM, but they may not be complete with all pin placements. This is a job that only a few mechanics are properly qualified for.
Old Nov 4, 2009 | 08:59 PM
G35-31's Avatar
G35-31
infiniti check and all prongs where correct so they said
Old Nov 4, 2009 | 09:14 PM
exZilaration
Register as in reading the ECU.
What dkmura just pretty much said is "yo wiring is f***ed up" lol
I hope you fix the problem bro
Old Nov 4, 2009 | 09:23 PM
G35-31's Avatar
G35-31
yea well i got a new ecu comming hopefully this fix's
Old Nov 5, 2009 | 01:31 PM
Cide's Avatar
Cide
sorry to tell u but it might not fix it. are u installing the new ECM or the dealer? because u need to register the key to the new ecm.
