need help with ignition coils
Old Nov 14, 2009 | 05:12 PM
redlinedifterzx's Avatar
redlinedifterzx
Default need help with ignition coils
OK today we were in the middle of some basic overhauls new oil tranny fluid diff fluid etc spark plugs
when changing out the spark when screwing the ignition coil back in the bolt snapped and of course is not stuck completely flush and will probably have to drill and tap it out. while pulling out the last spark plug the plug came out completely covered in oil as well the socket as the ignition coil came out in one piece but it wasn't giving that vibration when u shake it like the other coils had sort of like when u shake a light bulb u can feel the coil inside vibrate.
so i tap but the screw wasn't long enough but we wanted to see if the motor was still so my buddy was holding in the coil to make sure that it wasn't going anywhere(this is before we confirmed the other coil was broken and came out in two pieces) so when we start it up it was spitting like crazy running really rich
everything was connected properly i assure you
so i pulled out the suspect coil and of course it comes out in two pieces
so while i figure out where im gonna get a new coil from
do you think the issue was the coil and how would u explain the oil on the socket and spark plug as or is it something worse
Old Nov 16, 2009 | 11:07 AM
halfass872's Avatar
halfass872
Replace the coil, they are cheap, should fix your issue. Get it from an autoparts store. It's just as good, and you won't pay dealer markup. Be carefull drillign and tapping where you are. Your valve cover is plastic i believe. And the part that you snapped the bolt off into is only an insert.
There is a gasket (O-Ring) where your valve cover seals to the head. Those gaskets keep oil from seeping into the spark pluge tubes. You need to replace them. You might as well buy a whole valve cover gasket set since you are gonna need to replace the valve cover gasket when you remove your valve cover to chance the sparkplug tube gasket.
Old Nov 16, 2009 | 11:24 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
actually, be careful with the aftermarket coils - they are not "just as good" - the genuine Nissan ones, or the ones by the OEM maker, are your best bets, without question.
the OEM coils are 2 pieces...the tube screws into the coil pack at the top
the gasket at the coil is not replaceable, as it is part of the cover - if its leaking, you will need to purchase a new valvecover. The side seal to the head keeps oil from leaking down the head and block (keeps the oil in the top of the head) - has nothing to do with the spark plugs/coils
Old Nov 17, 2009 | 09:50 AM
Zazz93's Avatar
Zazz93
Yeah, I'm with Adam on the valve cover deal. However the valve cover is quite expensive (for what it is) at $200 per side. I had the same problem with oil getting into one of the spark plug tubes and I decided to use RTV sealant on the grommet/tube gasket and it has held up ok. On the aftermarket coils, to each their own. I would imgine the aftermarket version would be ok, but they are a pain to change so it might be a good idea to go with the OEM part.
Old Nov 17, 2009 | 10:34 AM
Z1 Performance
Former Sponsor
it does stink that the valvecovers are so expensive...especially for being plastic and nothing really special
for the coils, we offer the ones by the OEM maker for Nissan, and they are alot less than the dealer cost I would be even comparably priced to the ones at various autoparts stores
Old Nov 21, 2009 | 04:31 PM
redlinedifterzx
do i need a sealant to go along with the gasket when i reinstall the valve cover
Old Nov 21, 2009 | 04:51 PM
Zazz93's Avatar
Zazz93
Ideally, no. If your seals leak I woulrd replace those they are reasonably priced. However sometimes I use a little sealant to hold the seal to the cover, kinda like an adhesive.
lolwatbro
Oct 9, 2021 04:58 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
irishguy0224
Sep 22, 2015 06:57 PM
