Where is the oil pressure sensor located?
Old Nov 25, 2009 | 10:59 AM
Dr.TuB's Avatar
Dr.TuB
Default Where is the oil pressure sensor located?
Where is it located and how can i gain access to it?
Old Nov 25, 2009 | 11:09 AM
06Track's Avatar
06Track
It is right above or the oil filter. You will see the wires running to it and
it is round. Should be easy to spot.
Old Nov 25, 2009 | 11:12 AM
Dr.TuB's Avatar
Dr.TuB
where is the oil filter?
do i have to go underneath my car to find this?
Old Nov 25, 2009 | 12:12 PM
Maybe you should take the car to a mechanic. Just a thought.
Old Nov 25, 2009 | 02:09 PM
tylerxfire's Avatar
tylerxfire
i tried to save u from a flaming and pm'd u back, just take my advice and jack the car up and slide under and look for it..
Old Nov 25, 2009 | 06:23 PM
Blck350z's Avatar
Blck350z
... idk if we should offer him anymore advice... for his own safety! but here it goes
OP: if you do take this upon yourself.... USE JACK STANDS!
-Remove the under tray ( a few bolts and clips and it drops off )
-Then where the black oil pan is in the middle there will be a cylinder ( maybe white or orange? ) on the passenger side of the engine (thats the oil filter).... right around that area will be a brown sensor with two wires ( as stated above ) sticking out of the place that the oil filter is attached too.... Good luck!!!
Maybe I shoudln't ask this but ( curiosity killed the cat..) why do you need to know wher the sensor is?
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Stevo Z
Oct 3, 2015 09:14 PM
