is this normal idle oil pressure?
Old Dec 3, 2009 | 04:41 PM
cababah's Avatar
cababah
Default is this normal idle oil pressure?
2005 Touring 6spd screenshot taken after fully warmed up engine idling...
Old Dec 3, 2009 | 05:00 PM
DavesZ#3's Avatar
DavesZ#3
Could be, but it doesn't really matter. What's the pressure at 2000 rpm, 3000 rpm, etc?
At idle, it should be about 15psi which is hard to read on that gauge. At 2000 you ought to read about 45 psi, at 3000+ you ought to have around 90.
Old Dec 3, 2009 | 05:09 PM
cababah's Avatar
cababah
between 60 and 90psi
Old Dec 3, 2009 | 05:33 PM
VO...'s Avatar
VO...
Administrator
Moved...
Old Dec 4, 2009 | 08:13 AM
Zazz93's Avatar
Zazz93
From the FSM for a warm engine...
Idle speed More than 14 psi
2,000 More than 43 psi
If lower than this add oil until full and re-test. If still lower check for internal leaks.
Old Dec 4, 2009 | 10:56 AM
Z04's Avatar
Z04
DO NOT use your oil psi gauge to check or determine your oil level. that is what your oil dipstick is for. try reading your owner's manual
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
