Will the real TT maker please stand up?
Old Oct 20, 2003 | 06:58 PM
jesseenglish's Avatar
jesseenglish
Originally posted by spazpilot
On the returnless fuel system that we have did anyone notice that the TT kit PE is making comes with a regulator? Does this mean that on that kit we will have to install the return line? Asked Cheston but got no response. The only time you need a fuel regulator is you have a return system, so I guess that is how they fixed the bigger injector issue!! Any comments?
I hope you're wrong at least for the guys paying for installation of that kit. I don't see why they'd have to do something like that. Someone probably just called it by the wrong name or something.
Old Oct 20, 2003 | 07:17 PM
SSR Engineering's Avatar
SSR Engineering
Yes, your right about the PE kit, you'll have to modify your fuel tank insert a compression fitting and run a line all the way back to the tank. You could try teeing the feed line from the tank, but chances are the pressure will be greater and will over-come the return line.
Old Oct 20, 2003 | 08:24 PM
spazpilot's Avatar
spazpilot
I also believe greddy went this way because they couldn't get the injector pulse on the 440 small enough to keep it from running rich on the low rpm's. Is this what you will be doing SSR?
Old Oct 20, 2003 | 08:26 PM
SSR Engineering
We're going to do new injectors, fuel management, rising rate fuel pressure regulator, fuel return line modification, just to make it a conventional returned fuel system.
Old Oct 20, 2003 | 09:15 PM
spazpilot's Avatar
spazpilot
I think this the way most people are resolving there fuel management problems
Old Oct 21, 2003 | 02:26 AM
SSR Engineering
It works, why change what works.
Old Oct 21, 2003 | 07:41 AM
jesseenglish
Why are you doing that? The FMU does the same thing, but without having to plumb a return line in. The only advantage I can see is that it's a mechanical item instead of an electronic item. You still won't solve any ECU issues unless you have some way of controlling the injector pulse.
Old Oct 21, 2003 | 09:34 AM
SSR Engineering
lol an FMU, thats kind of ghetto, it might work, but there's no way you could run larger injectors, tune an FMU for larger injectors and have a streetable TT kit. You'd probably have problems tuning your kit for low RPM 0 boost, considering Fuel pressure would be the same and you are runing larger injectors.
we are controlling Injector Pulse.
Old Nov 3, 2003 | 06:05 PM
bbd's Avatar
bbd
As soon as HKS makes a kit, i will be all over it.
or Apex.....
Old Nov 3, 2003 | 06:23 PM
vincenzobar's Avatar
vincenzobar
the 2001 civic d17A had to do this too. They had to run a return fuel line in order to get the FI to work. Its the new technology and FI isn't keeping up! hell the civic doesn't even have a distributor! does ours?
anyway the after market doesn't have millions of dollars for R&D so they just do the best they can to keep up with technology. If adding a return fuel line is the biggest headache than that isn't so bad in retrospect!
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Extreme Dimensions
Body Exterior
Nov 9, 2015 10:47 AM
cashmoney03
Sep 27, 2015 05:24 PM
Tochigi_236
Sep 27, 2015 03:40 PM
