the missing gear
Old Jan 11, 2010 | 09:12 PM
redlinedifterzx's Avatar
redlinedifterzx
Default the missing gear
Ok this comes from personal experience but when pushing the z hard into the corners on the track its seems to me there should be another gear in between 2-3 i often find that 2nd gear is to slow for the long sweeping corners but good for the technical tight corners and 3rd gear is to high of a gear for the long sweeping corners instead of redlining it im often caught at around 4-5 rpms and have to break a lot harder without relying on engine braking which often through s me out of the corner. I don't claim to be the best driver around but it seems to me that there really should be another gear even professionals although i cant remember his name (Japanese) quotes the same thing
Would installing 3.9 fd gears help or does just more experience and better suspension all around make a better difference
Old Jan 19, 2010 | 08:42 AM
vthao's Avatar
vthao
MMhhmm...
There should not be a 2.5 gear
Better brakes = better braking
Old Jan 19, 2010 | 03:37 PM
terrasmak's Avatar
OK where to start. First, all tracks are different, and if your setting up a full track car you will probably have different gearsets for different tracks. If you want, yes you can change your gearset or since yours is still a street car , just change to a shorter rear tire 275/35-18 or 275/40-17 makes a very nice difference and similer to changing rear end ratios. Last, just learn to drive, and figure out what gear is actually faster thru those sections. I use the Torque of the VQ a lot, and move well around the track.
BTW brakes are for braking and clutch is for shifting. If you rely on eng braking to the point where it can effect your brakes. YOUR DOING SOMETHING VERY WRONG.
sherm
Apr 11, 2020 05:21 PM
Jambo016
Sep 16, 2016 01:08 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
