p0455 Sensor. need help.
Old Jan 23, 2010 | 07:26 AM
VS 350Z's Avatar
VS 350Z
Default p0455 Sensor. need help.
the p0455 sensor. what exactly is this? does this usually cause problems? how much is it? could i clean it at all etc?
Old Jan 23, 2010 | 08:19 AM
TheFarmer's Avatar
TheFarmer
P0455 is a large EVAP leak. How long has your check engine light been on? What were you doing when it came on and did you recently hit/install/mod/fab/touch/play with anything on your car?
Old Jan 23, 2010 | 08:21 AM
cdoxp800's Avatar
cdoxp800
Here is some info on that code
http://www.nissanhelp.com/diy/obd_codes/p0455.htm
Old Feb 3, 2010 | 08:06 PM
hawghunter08's Avatar
hawghunter08
Thats a gross evap leak code as thefarmer said, most commonly caused by leaving the gas cap off... but youve probably figured that out by now..
aarrgghh
May 1, 2022 11:04 AM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
rizzla
Sep 29, 2015 03:58 PM
