Got Stillen Blower, now what?
Old Oct 24, 2003 | 12:47 PM
slingshotz's Avatar
slingshotz
Default Got Stillen Blower, now what?
The blower is on and everything is good to go, however I would like to make some more power. I have done numerous searches and didnt come up with much.
Best header/exhaust?
should I look at a S-AFC or Power FC?
Flywheel/Clutch?
All opinions welcome.
thanks
Old Oct 24, 2003 | 01:29 PM
zland's Avatar
zland
Sport Z Magazine
just dont mod it in anyway to make it run lean....
Old Oct 24, 2003 | 01:35 PM
slingshotz's Avatar
slingshotz
Default VENDORS
where to buy such products?
Thanks
Old Oct 24, 2003 | 01:58 PM
jesseenglish's Avatar
jesseenglish
clutch and tires are probably your best mod right now. Headers, exhaust etc, aren't going to give you any HP gains on an FI engine.
Old Oct 24, 2003 | 02:05 PM
MY350Z.COM's Avatar
if you want more power, get an ATI Procharger IN ADDITION to the stillen s/c
Victor
Old Oct 24, 2003 | 02:14 PM
jesseenglish
Yeah, you could always get a nitrous shot after the SC, that would help cool things down and prevent the detonation problem that's been seen with the Stillen SC. Plus more power.
Old Oct 24, 2003 | 02:26 PM
FLY BY Z's Avatar
FLY BY Z
And of course JesseEnglish was on crack like Calvin when he said this.
Old Oct 24, 2003 | 03:50 PM
Turcoupe's Avatar
Turcoupe
I know right ! How can headers and a less restricitve exhaust not benefit a supercharged Z ? Your car still needs to breathe....
Old Oct 24, 2003 | 04:10 PM
Ralphus's Avatar
Ralphus
Headers, intake, and exhaust are very important on FI. The more freely things flow, the more power that thing will produce.
While the Z's intake and exhaust aren't the most restrictive stock units, I think it's crazy to have an SC and not have the exhaust mods done before hand. Your motor is a pump, the SC is helping it pump more, but you forgot to increase the size of the pipes.
Old Oct 24, 2003 | 07:23 PM
jesseenglish
My bad, I meant to say it won't give much gains. Not really worth it IMO, because the stock system is so well designed. The money would be much better spent on transferring the power to the ground.
Old Oct 24, 2003 | 07:27 PM
Yielar's Avatar
Yielar
The hp increase by adding both an intake and exhaust will be more noticable on a boosted engine.
Old Oct 25, 2003 | 07:56 AM
spazpilot's Avatar
spazpilot
slingshotz
I would first wait for stillen to release the air to water intercooler for there SC. That will be the best gain power per dollar. Then find out what the A/F ratio is on the car. If its safe i would run headers, exhaust, and intake. you will benifit from it. just my .02
Old Oct 25, 2003 | 10:55 AM
reen's Avatar
reen
I hate to jump on the bandwagon here, but with a supercharged/turbo engine, exhaust work is a MUST. Simply put, you're cramming all of that extra air in there and you have to get it out as efficiently as possible.
One time (geez, ~10 years ago now) I put a vortech supercharger into a Saleen Mustang (stock 302) and ran it that way for a while. It was much quicker, but not how I felt it should be. After adding headers and a high-flow exhaust system it really came alive.
I ended up adding different injectors, big fuel pump, fuel pressure regulator, and ECU mods to deal with it all. Then it was sweeeet.
Superchargers are great, but they're "part of this complete breakfast" if you catch my drift.
Old Oct 26, 2003 | 07:10 AM
DaveO's Avatar
DaveO
A 2.5" system made for FI.
Old Oct 27, 2003 | 08:59 AM
slingshotz's Avatar
slingshotz
Default Thanks to most of you
I appreciate the help from some of you.
Where is the best place to get the exhasut pictured?
I was thinking of getting the nismo full exhaust sytem but I am having a bit of trouble finding the right vendor.
Old Oct 27, 2003 | 09:46 AM
Dissolved's Avatar
Dissolved
This would of been better put: mod it away, but make sure you get tuned
Yep. A small shot (maybe 50-75) would cool the cc's. However, I would rather run an intercooler than use this primitive method
Old Oct 27, 2003 | 02:55 PM
ForceInduction's Avatar
ForceInduction
Look into some colder set of spark plugs, maybe an exhaust system, or even a clutch. Or you can get some nice gauges or even a wide band 02 setup so you can see what your car is doing. This is a good start.
You may want to hold out on other modifications due to the fact that, there is no good stand alone systems or chips available yet. Pretty much any modification you make to the engine will increase the airflow and there is a possibility that your engine might run lean. Headers, high flow cats, cams, and intake manifolds might just off set your tuning. Once a company comes out with a good chip or stand alone, you will be more open to other accessories you can add to your engine. Once they come out with this, your possibilities are endless.
Bodyboarder81
Nov 2, 2015 12:17 AM
kyin
Oct 15, 2015 05:54 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
Nicky R
Sep 20, 2015 01:05 PM
