apexi safc11
Old Oct 26, 2003 | 02:26 PM
mario60185's Avatar
mario60185
Chicago Realtor
Default apexi safc11
i need help from all the tuning geniuses...i am thinking about getting the safc11 but i heard that if you want to tune it yourself you obviously need an air to fuel gage but i also hear that they are not accurate on our car because we need a wideband 02 sensor. forgive me for being dumb but what the hell is a wideband or narrowband o2 sensor. and where can i get one. also if i have a air to fuel gauge and wideband 02 sensor how does that all work with the apexi unit...any help at all is greatly appreciated , thanks guys...oh, and gals!
Old Oct 26, 2003 | 03:17 PM
Dissolved's Avatar
Dissolved
Wideband02 sesnor allows you to tune your car at WOT with an a/f gauge ACCURATELY. If you were to connect an a/f gauge to your stock 02 sensor, it would really only serve 1 purpose: To let you know when you enter closed loop. In other words, a/f gauges with your stock 02 are worthless. (unless you like looking at crosscounts). Stock 02s are on your car to keep you at a 14:7 a/f ratio. It determines rich/lean by voltage
Widebands ARE accurate and can be used to adjust a/f ratio at WOT. They give you actual a/f ratio and are not a guesstimate
Old Oct 26, 2003 | 09:07 PM
Dissolved's Avatar
Dissolved
Default Re: apexi safc11
also....to answer the rest of your question....the dyno shop installs a wideband temporarily on your Z. The SAFC11 is tuned while the wideband is installed. This is why the directions say to have a professional tuner do the tuning. After it's tuned, they rip the wideband out and send you home.
Old Oct 26, 2003 | 09:54 PM
SlamMan's Avatar
SlamMan
Exactly, except as far as I know you car should run around 12.5:1. Stoich would be too hot.
Old Oct 27, 2003 | 06:46 AM
Mike@Altered's Avatar
Mike@Altered
A wideband 02 meter normally uses a five volt output (wide band) rather than the traditional one volt output (narrow band) 02 sensor most of us are used to (and comes factory in most vehicles).
When tuning a S-AFC II, its best to do so on a dyno equipped with a wideband 02, but if you want to tune yourself I would suggest a wideband meter from FJO or, my favorite wideband controller, the HKS Knock-Amp. Both use wide band sensors which are extremely accurate, and both will give you a reliable a/f reading. The n/a nissan likes to run close to 13:1 at WOT for best power. If you really want to tune your car to the "T", I would also suggest adding a good peak/hold EGT Gauge. The Exhaust Gas Temp. gauge measures the temperature of your exhaust gases, and this gauge can become particularly helpful down the road if you decided to go with a supercharger or turbocharger upgrade.
Hope this helps,
Dr.Paulyy
Jul 29, 2019 07:45 AM
GTO2350
Aug 21, 2004 11:47 AM
silverstoneTT
Jun 11, 2004 12:47 PM
drivenCSZ
Apr 4, 2004 03:06 PM
valuetl
Mar 28, 2003 05:45 AM
