Fuel pressure??
Old Mar 1, 2010 | 09:06 AM
danegilli's Avatar
danegilli
Default Fuel pressure??
I have a 2006 MT, hearing that i should have 51psi fuel pressure from the nitrious write up....my prosport gauge reads 61-62? This a problem or should it be at 61?
Old Mar 1, 2010 | 09:17 AM
qqqqball's Avatar
qqqqball
not necessarily a problem,the higher pressure will make stock injectors spray like they are a little bit bigger, maybe not the best pattern. IF your running the stock ecu with no mods at 65psi the ecu cuts the fuel
Old Mar 2, 2010 | 06:44 AM
brotus's Avatar
brotus
I also have a fuel pressure gauge from prosport and it has read high from day one. I don't think they are the most accurate gauges. If yours is still under warranty you can send it back for them to check.
apex locator
Jul 23, 2021 02:27 AM
