Overheating Issues
Old Mar 2, 2010 | 01:04 PM
kingklay's Avatar
kingklay
Default Overheating Issues
Wondering if you guys could help me out.
came home from work the other day and as soon
as Iparked and shut off the engine, I got steam and coolant
comming out everywhere.
So after searching on forums I tried the following:
jacking up the car, opening the rad cap and getting the car
to opertating temps. Also opening the bleed valve by the firewall
and adding coolant. Is there anything I missed to get the air bubbles out??
I took the car out for a drive and it started to overheat within 5 minutes, while I was driving I had the hot air on full and was only getting cold air comming through.
Is this a sure sign the thermostat is the root cause?
any info would be highly appreciated!
Thanks!
Old Mar 2, 2010 | 02:32 PM
kramykram's Avatar
kramykram
quit possible. i would also check that your cooling fans are working to. just turn the ac on while the car is parked. but i would not drive to far overheating as you can really mess up the alimunum block.
Old Mar 2, 2010 | 02:45 PM
kingklay's Avatar
kingklay
Fans are working so its not that and I hear ya I do not want to blow a head gasket
Old Mar 4, 2010 | 07:03 AM
kingklay's Avatar
kingklay
Turned out to be the thermostat. All covered by the powertrain warranty.
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
