VQ35DE vs. 2JZGE
Originally posted by BriGuyMax
Speaking of misinformation....the Supra is NOT a dyno queen because of the diffuculty of launch....rather the very UNUSABLE powerband of sometimes as little as 1500rpms with the bigger single turbo applications. It's simply useless for anything but going fast in a straight line with that small of a power band.
super high HP supras are always going to be a bad road race car.. but that goes for just about any car. I don't think I'd want to road race any car with heavy turbo lag and enough power to roast drag slicks.
Originally posted by Pure Tremble
by the way, where did you run your 13.66 at? That's very good
US-141 Raceway in Michigan....not the track I usually go to....plus US-141 is considered to be a rather slow track....It's a great facility and the track is REALLY sticky....people tend to run low traps though...
Originally posted by Hraesvelg
What an open deck and what's a closed deck?? Sorry for the O.T. hijack...
Strength wise the closed deck block has more surface area connected to the block itself so there is more reinforcements.
Regards,
Jeff
VQ and 2jZ are different type of engine. WHy don't we compare VQ and C32B from NSX? that will be more interesting.
oh 2JZ-GE and 2JZ GTE are different internally. However, their block are stronger than VQ, becuase of the material. And ususally stronger block means higher boost, which result in higher HP.
There was a thread on Supraforums where someone was asking what the best pistons for the money was for a 2JZGTE. The answer wasn't Wiseco, JE, or anything like that. It was OE pistons with aftermarket rods. Just that alone should tell you something about the motor.
yep yep i love supras. Almost bought a '93 mkivtt back in 98 for $18k (yes, you could get them relatively cheap before fast and furious). Black 6spd in philly. Still kicking myself for not buying it. May still get one....
2JZs are so sturdy and well designed, in fact, that Supra owners very rarely swap out the pistons. It's always OE pistons and aftermarket rods. Peter Blach of Supraforums.com, as well as a few others, have produced 1000+ crank (Blach dynoed 958rwhp) on stock internals
I think a lot or people are confused. This is comparing a 2JZ-GE to a VQ35DE, not a 2JZ-GTE. The GE(non-turbo) is a very different animal from its turbo brother. It has a cast bottom end, weaker block and mains and a thiner casting head just to begin with. 2JZ-GE's have been known to frequently come apart above 400 rwhp. 2JZGTE(twin-turbo motors) have extremely strong bottom ends with forged pistons and rods. As long as you have them tuned properly on the right fuel, they can run 600-800 rwhp without ever touching the bottom end or haivng the head removed from the block. They have extremely beefy mains. The heads and intakes have a shorter smoother flow design to work better with boost. This is why the NA(GE) turbo kits are usually in the 380 hp range. For durability, the VQ35DE has only 1 weakness: the rods. VQ rods are very thin(<1.0") and can only take so much abuse. Sure the pistons aren't forged, but it will take a good amount of detonation to melt them. Still, the VQ35 out of the box seems to handle a maximum of 440 rwhp before the stability becomes questionable.
Keep in mind that the RB26DETT from the Skyline is as strong as the 2JZ-GTE is. Like the GTE, it has a forged bottom end, solid block and beefy mains. Nissan is replacing it with the VQ35DETT which will be a beefed up version of our engines made to take heavy boost. How much will be different, we won't know until they are ready to release that info.
They already have a VQ30DET(single turbo) that has been on same in Japan for several years in 270-280 hp versions in the RWD sedans. The GTR is supposed to have a version of the VQ35, not the VQ30 from what I've read.
like we've covered already:
The GE (N/A) block is I-D-E-N-T-I-C-A-L to the GTE block. it's not cast, and it's not weaker. The GE only lacks a couple of piston oil squirters, and the pistons are higher-compression, but made of the same material as the GTE pistons. The only reason GE turbo kits make less power is because of the higher-compression pistons leading to detonation. The head design is quite different, but it doesn't really stop the engine from making power.
The VQ does suffer from weak rods, but it also has the issue of an open deck, which worries me a whole lot more.
and one last point -- the RB26 isn't as tough as the 2JZ. The design is not as good and won't yield as much power on the stock block. A 2JZ-GTE will hit over 900 RWHP on a stock block, and the RB breaks down around 650.
Originally posted by azrael
..., but it also has the issue of an open deck, which worries me a whole lot more.
