Help: transgo vb upgrade
Old Mar 18, 2010 | 05:08 PM
chimchim's Avatar
chimchim
Default Help: transgo vb upgrade
Sorry guys, but I need some help.
I'm in the middle of the transgo vb upgrade and I have a question for those
that have installed it themselves.
For the second valve it states,"remove this spring. It is weaker than the other two." Is that corrrect??
When I put the new valve in without the "big" spring, it seems to have very little resistance to keep it wedged in the body....thanks
Old Mar 18, 2010 | 11:31 PM
dirtbikr's Avatar
dirtbikr
This is correct, leave that spring out completely. I also have a question. After the valves are replaced, and you move onto the springs, some of the images in the guide show one spring inside of the other, is this how it truly goes? You take the old spring and put it in the middle of the new spring?
Old Mar 19, 2010 | 09:48 PM
chimchim's Avatar
chimchim
I finished the install this morning. She shifts like a bat out of hell.
About the springs. Yes, you take 2 new springs and replace 1 of the old ones. You either
use 2 white colored spring or 2 plain colored springs depending on what valve you have in
your valve body. You also have a blue and a yellow colored spring to replace 2 other springs.
dcains
Nov 11, 2015 11:36 PM
