Nismo LSD now installed
Old Oct 30, 2003 | 01:23 PM
apex locator's Avatar
apex locator
Originally posted by yobri
Hey Jeff, how often do you think the diff fluid needs to be replaced with the Nismo version?
probably every 3k miles
Old Oct 30, 2003 | 02:15 PM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
I will find out for sure. I was told after the break in to do it every 30K would be fine? I'm sure someone here will have the correct answer.
Old Oct 31, 2003 | 06:37 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
NISMO = Cusco MZ
Old Nov 2, 2003 | 07:26 PM
Gsedan35's Avatar
Gsedan35
Originally posted by kzshin
can it be used on the base model 350Z?? which doesn't come with stock LSD.
As long as it comes with everything you see in the picture. Especially the stub axles to the left, the non limited slip Z uses stub axles that are equal length, whereas limited slip stub axles are not equal length. It's not a clip modification or machince shop thing. I just got my car out of the shop from basically doing a base to limited slip install, I had NO choice but to buy the LSD stub axles, (part numbers 38220-AR011 and 38220-AR010, $148 each). If that Nismo LSD comes with everthing that Jeff shows in that picture he posted at the beginning of this thread, for $900 the Nismo will save you some additional parts purchases to the tune of a additional $400!!! (stub axles, seals and bearings).
Thank god Jeff sold me as slightly used stock VLS for less than $200, cause I just paid $400 labor +$400 in parts to install it. I should have waited for the Nismo, oh well.
Old Nov 2, 2003 | 07:38 PM
raceboy's Avatar
raceboy
Originally posted by Z1 Performance
NISMO = Cusco MZ
How can it be the MZ when you can adjust it without removing and restacking the plates?
Old Nov 3, 2003 | 03:58 AM
John's Avatar
John
Depends on what you're doing with the car. For around town driving, you should be fine for a diff fluid change every 30K. However, if you actually track the car where you expose the diff to high temperatures for long periods of time, then the fluid will break down. I'd got to guess that you'd be safe changing the diff fluid every 15 hours of track time (plus some normal driving miles too).
Old Nov 3, 2003 | 02:35 PM
Z1 Performance
Former Sponsor
raceboy - I need to try and find of pic internally of the NISMO LSD to see for myself - I was abit premature to jump the gun, as its what my suppliers in Japan had told me, but they could certainly be wrong
Old Nov 3, 2003 | 03:21 PM
ttheisen93's Avatar
ttheisen93
At 60% is this modification noticeable in normal driving? I'm using my base model as a daily driver, so I'd like to upgrade to LSD, but without my wheels hopping and acting strange when I'm not driving "spiritedly". Please post how 60% goes for laid back driving.
Old Nov 3, 2003 | 04:11 PM
Jeff@Performance
Performance Nissan
I'll let you know when I get back from SEMA. I didn't have time to change it to 60% yet.
Old Nov 3, 2003 | 07:31 PM
raceboy's Avatar
raceboy
My Cusco type RS goes in of Thurs(finally!) I will also be setting it for 60%. I would have bought the NISMO one, but at the time, I didn't even know the NISMO one was coming any time soon.
Old Nov 3, 2003 | 07:32 PM
FLY BY Z's Avatar
FLY BY Z
Will this provide any benefit for straight line acceleration or primarily just for road racing?
Old Nov 8, 2003 | 01:13 PM
nigevellie's Avatar
nigevellie
i'd love to hear the answer to this also. thanks
Old Nov 8, 2003 | 01:33 PM
Traffic's Avatar
Traffic
Can't speak for the Nismo LSD but my Kaaz did wonders. The diff would lock up and the car would hook up. Traction was amazing
Old Nov 9, 2003 | 02:02 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Whta kind of imrpvement in 0-60 or1/4 mile did you see with the Kaaz LSD.
Thinking of installing it in my G.
Gurgen
Old Nov 12, 2003 | 04:24 AM
Jeff@Performance
Performance Nissan
Just an update.... Finally had the time to reset the diff to 60%. All the funny popping and wheel dragging in the parking lot are gone and it still hooks up strong when you hammer the throttle. This is the perfect street setting. Anything more than that was just too much for a street car.
Old Nov 12, 2003 | 04:07 PM
uro279's Avatar
uro279
How does this affect the "Tracktion/VDC" system?
Old Nov 12, 2003 | 04:33 PM
Jeff@Performance
Performance Nissan
Good question, I don't have the VDC, and I usually turn off traction contol when I drive. If I leave the traction control on it doesn't seem much different other then the light flashes now and then telling me it activated the system. I'm sure someone with a VDC can chime in here.....
Old Nov 12, 2003 | 06:51 PM
  #38
GurgenPB's Avatar
GurgenPB
UltimateSleeper
hey Jeff
This LSD will fit in a sedan right?
gurgen
Old Nov 12, 2003 | 08:44 PM
  #39
Gsedan35's Avatar
Gsedan35
Originally posted by gurgenpb01
hey Jeff
gurgen
Trust me, yes it will.
The Z and both G's are the same part for part on the drivelines, non LSD's are the same and LSD are the same. Only difference's are a function of the different wheelbase, their the Z get's the trick drive shaft.
Old Nov 12, 2003 | 09:24 PM
  #40
GurgenPB's Avatar
GurgenPB
UltimateSleeper
cool
