Coolant leak?
Old May 6, 2010 | 08:51 PM
BonesZ33's Avatar
BonesZ33
^^ agreed.. save the money on the popcharger... so later you can put it towards a turbo :P
Old May 7, 2010 | 09:20 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Jeffie, nice pics you provided. It does look more simple than i orginally thought...just have to remove a ton of plastic to expose the entire line.
In your second pic, thats def the line that attaches into the firewall closer to the battery compartment. Its the smaller line, the one to the right of the bigger metal line when looking head on at the bay.
Old May 7, 2010 | 11:54 AM
jeffie7's Avatar
jeffie7
One sends the compressed gas and the other one returns it. both go to the firewall and both end up going into the compressor.
It's not all that bad.
Old May 7, 2010 | 01:00 PM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
Although it's not the best long term solution that could be repaired with a compression fitting (union type) as well, assuming that one could be sourced in the correct size to fit that tubing. Just cut out a small section around the hole and patch the line back together with the union.
Old May 10, 2010 | 07:20 AM
PSUpride's Avatar
PSUpride
Thanks everyone. I am going to stop at a shop on Thursday to see what they think. If it can be patched - then I will def go that route. Here is a zoomed out pic with the line and the problem area circled just for future reference:
Thanks to Jeffie for the PM with all the info on how to fix it myself.
Twenty4
Jan 17, 2016 01:20 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
SharX59
Sep 27, 2015 09:23 AM
