CAMP2 Help
Old May 11, 2010 | 01:14 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Default CAMP2 Help
Does anyone know what the clibration numbers should be on the CAMP2 should be for a 2006 revup?
I can't get the throttle position to go beyond 80%, and my fuel meter is way off.
Thanks
Old May 11, 2010 | 09:09 AM
jonnylaw's Avatar
jonnylaw
Type: Nissan2
Connector: 2
ECO CORRECT: 1800
This is per the HKS CAMP2 Application List
What ems are you using? The fcon vpro for some reason is not compatible with the Eco mode apparently.
Interesting you mention throttle. Mines been reading lower at WOT recently., However, when I turn the car to the "on" position and floor it, the throotle% reads ~98%. I will check my settings; perhaps my throttle position tables are off.
Old May 11, 2010 | 11:56 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Ok cool. I'll try that.
I'm still using the stock ECU
The throttle position is really bugging me as it never goes above 85%. I know there is a throttle calibration in the settings, but i wouldn't know where to start. Maybe i'lljust fiddle with the numbers to see what happens.
Old May 11, 2010 | 12:07 PM
jonnylaw's Avatar
jonnylaw
^^Try pressing down on the gas pedal, with the ignition in the "on" position, with the engine off, and see what the throttle position reads on the Camp2.
I wasn't aware there was throttle calibrations settings on the Camp2. Can you elaborate?
adm.gregory
Sep 1, 2015 12:15 AM
RoTors350Z
May 6, 2012 05:41 PM
AmnCruzie
Jun 24, 2010 11:17 AM
