Jwt clutch flywheel combo
Old May 6, 2010 | 07:47 PM
bjjbadboy's Avatar
bjjbadboy
Default Jwt clutch flywheel combo
First thanks for everyones help sure most have seen me posting in the past. After now like 3 months my baby is semi back. and I love the combo, still getting used to it but not bad at all, and the chatter is really next to nothing litteeraly. I def recomend this kit for a mild upgrade clutch/fly combo. I still say semi because has to be bleed better. It turns out I did need a new slave after having the car towed(thank god insurance covered) and payed 50 bucks to have it bleed, dude called me to pick it up I get in still cant get into gear b/c no pedal. so charged me 80 for the slave. My pedal is still hanging half way so there gonna have to rebleed it again. but i got to drive it and love the clutch love my pop charger and got the mod itch all over again
Old May 6, 2010 | 07:50 PM
ITOzann's Avatar
ITOzann
na?
Old May 7, 2010 | 12:05 AM
Z You Later's Avatar
Z You Later
the combo you purchased was the clutch/flywheel right? who installed it for you? the chatter is normal for the lightweight flywheel but never heard of it causing this issue. sounds like you are having either a bad slave cylinder install or something is leaking to cause the "no pedal" effect. You may need something as simple as a clutch adjustment or even worse they installed something wrong which is giving you your problems.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
