stripped flywheel bolt
Old May 8, 2010 | 03:17 PM
Dib07CE's Avatar
Dib07CE
Default stripped flywheel bolt
apparently my flywheel was torqued down to about a billion psi. one of them is stripped now. what's the easiest way to get that s.o.b out?
fml
Old May 8, 2010 | 03:19 PM
phreaktor's Avatar
phreaktor
Design Engineer
Cut a slot in it with a Dremel and use a flathead screwdriver.
Old May 8, 2010 | 03:26 PM
westpak's Avatar
westpak
SFZCC
extractor
Old May 8, 2010 | 03:27 PM
BonesZ33's Avatar
BonesZ33
Drill a hole in the middle and use a screw extractor, .. spin the flywheel so that the bolt is on the bottom so you can fit the drill in there.
watch this video.. if you drill it correctly it should come out easy without hammering or having to use a breaker bar.
http://www.youtube.com/watch?v=i_g_o...eature=related
Old May 8, 2010 | 03:38 PM
Dib07CE's Avatar
Dib07CE
^^^thanks bones, forgot about those
Old May 9, 2010 | 04:00 AM
MR RIZK's Avatar
MR RIZK
I would try that extractor that wetpak suggested first before using the internal type extractor.
Old May 12, 2010 | 01:19 PM
winterdevilg35's Avatar
winterdevilg35
you could always drill into it then use an e-z out..... when you change out the bolt make sure you replace all of them with hex head bolts because it's very easy to strip out those star pattern bolts.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
