copper turbo kit piping
Old May 12, 2010 | 09:12 PM
  #41
snobes's Avatar
snobes
Originally Posted by SexyRob
could just clear coat the copper to prevent corrosion.
also to T_K you are dumb if you think a metal that absorbs heat faster will release it slower.
please take a gen chem 1 class before giving anymore of your "FACTS"
the fact that copper will absorb heat faster than aluminum has no bearing after idling for 5 minutes... either way the temps of the pipes will normalize no matter what metal it is. the good thing about copper is after driving your metal will be more affected by ambient temps and and cool down faster than the aluminum.
The cost of the Cu and the added weight makes it difficult to beat aluminum for this application, regardless of thermal dissipation.
If your good with chemistry you would know that putting a clear coating over the copper will reduce its effectiveness.
and everyone seems to be forgetting that the temps in the engine bay will probably be warmer than the air in the pipe so we dont want heat transfer.
If the pipes had cold air flowing over them they still wouldnt help much as the surface area of the piping is small compared to an intercooler.
as for a copper cored air to air intercooler, it would help but it would weight a **** load.
Old May 13, 2010 | 03:38 AM
  #42
SexyRob's Avatar
SexyRob
I didn't say clearing them wouldn't change the thermal conductivity, now did I? I said it would prevent corrosion.
Old May 13, 2010 | 11:38 AM
  #43
crsracing19's Avatar
crsracing19
if your worried about heat transfer use a thicker tube although you adding to the weight
Old May 13, 2010 | 07:40 PM
  #44
snobes's Avatar
snobes
but we are doing this to improve the intercooler, going to copper but then losing the advantage of copper by coating them gets us no where.
edit: spelling
Old May 15, 2010 | 06:17 AM
  #45
SargeZ350's Avatar
SargeZ350
Hey guys. i´m wondering if anybody tried to do the piping in carbonfibre? i´m actually planning to do so with my gtm kit. please tell me if this is complete bs or a good idea. thx
Old Jun 3, 2010 | 11:27 AM
  #46
scotts300's Avatar
scotts300
You mean your turbo piping will be CF instead of aluminum? What are you trying to gain from such an expensive switch?
Old Jun 3, 2010 | 11:36 AM
  #47
SexyRob's Avatar
SexyRob
well it would probably be something wrapped in CF... its hard to lay out CF tubes, especially around all the bends.
Old Jun 3, 2010 | 12:38 PM
  #48
scotts300's Avatar
scotts300
Precisely why I was asking what his plan was, and I don't quickly see an advantage to any kind of pipe that is overwrapped with CF minus the bling and the brag.
Old Jun 26, 2010 | 12:46 AM
  #49
SargeZ350's Avatar
SargeZ350
Well i wanted to do the piping in full cf. no overwrapping. no real gains here. just because i can The only thing i worry about is the pressure. I´m running around 20psi. But i think the piping should be stron enough to handle that.
Weight saving? Less than 10% But maybe i could change some of the piping to get rid of some samco couplers?! The whole thing was just a "what crazy stuff could i do next?!" thing
Old Jun 26, 2010 | 11:18 PM
  #50
scotts300's Avatar
scotts300
If you have money to burn buy a 997 Porsche 911. Honestly, I see no advantage to running carbon fiber for intercooler piping. It certainly can handle 20psi without issue, but there is no advantage and is a waste of money - period. If you want cool CF parts, get the CF wheels that are actually lighter and stronger than traditional forged wheels.
Old Jun 27, 2010 | 03:56 AM
  #51
SargeZ350's Avatar
SargeZ350
i produce this cf stuff myself. no need to buy. those fc rims are sick bot there will never be any chance to drive around with them in germany
sales@czp
Sep 23, 2019 03:30 PM
