My theory on Z drivetrain loss
Old Nov 3, 2003 | 05:05 PM
PoWeRtRiP's Avatar
PoWeRtRiP
Default My theory on Z drivetrain loss
Well i for one am somewhat disappointed at the relatively low dyno numbers of stock z's. A 287 hp car at 15% loss should be around 243 to the wheels while at 17% it would be 238. Since the avg stock dyno seems to be around low 230-240 its possible that nissan overestimated the engines power. But heres what i think. Since the Z uses a timing chain rather than a belt its possible that it has higher than avg drivetrain loss. Almost all sportscars, even cars in general use a timing belt which weighs a lot less than that chain. So im hoping for some input from some techs out there could this be where some of that extra power is going to?
Old Nov 3, 2003 | 05:09 PM
FLY BY Z's Avatar
FLY BY Z
It's RWD which always experience more than 15% loss. Are you kidding? There is nothing wrong with our drivetrain loss, it is very avg.
Old Nov 3, 2003 | 05:12 PM
PoWeRtRiP's Avatar
PoWeRtRiP
As far as i know RWD has the lowest drivetrain loss of all. I was under the impression that 15-17% is avg drivetrain loss on a manual tranny rwd. If im mistaken plz let me know what is right.
Old Nov 3, 2003 | 05:17 PM
ponykiller's Avatar
ponykiller
I know that RX7s (front engine, rear wheel drive) with a 5 spd transmission have a 17% drivetrain loss, so the 350Z are fine.
Old Nov 3, 2003 | 06:02 PM
jeffw's Avatar
jeffw
When considering drivetrain loss you need to at least take into account whether you have a manual or automatic transmission, transverse or longitudinal mount engine, and front or rear wheel drive. FWD cars tend to have transverse mount engines (sideways). This means that the engine spins in the same direction as the wheels. This is more efficient than a longitudinal mount RWD car because the differential has to change the direction of rotation of the drive shaft and isn't 100% efficient in doing so.
Most rear and mid-rear engine cars have transverse mount. This is probably the ideal setup in terms of sports car ability.
Also, you never see transverse mount front engine RWD cars because the direction of rotation would have to make two 90 degree turns. Though there are some AWD cars with transverse engines and are very inefficent.
All that said, I think 17% is about right for the Z.
Jeff
Old Nov 3, 2003 | 06:29 PM
Ben Davis's Avatar
Ben Davis
not to mention that DRIVE SHAFTS (no matter how light) and LSD's take away power too
Old Nov 3, 2003 | 07:03 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I wonder how I dyno'd 243whp if my car in overrated?
Old Nov 3, 2003 | 07:06 PM
spazpilot's Avatar
spazpilot
they might have dynoed it in 4th gear instead of 5th which would show better numbers
Old Nov 3, 2003 | 07:18 PM
sschmuve's Avatar
sschmuve
I bet the A/C is left on at least half the time. That should be around 3-5 hp right there. So worst case scenario would be a/c left on, and dynoed in 4th.
Old Nov 3, 2003 | 07:20 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I was being sarcastic....btw....I drove my car on the dyno and it was in 5th.
My point was that the Z is NOT OVERRATED.
Old Nov 4, 2003 | 09:18 AM
bbd's Avatar
bbd
this is a good read.
Dyno Thoughts and HP Losses
After reading various articles in numerous publications on dynos and horsepower, I feel I should put forth a few observations:
Chassis dynos are great tuning aids but they only give a approximation of power output as some of the important variables are not accurately controlled. Certain magazines seem to think that results obtained from chassis dynos are the gospel. They are not. In one recent independent test, hp figures varied by 11% simply by doing the runs in different gears and in another test, results varied by almost 4 % by doing the runs with a different wheel/tire combination. Tire alignment has been shown to affect results up to 3% as well. Note that Engine hp DID NOT change here yet the dyno recorded an increase in hp at the wheels. A change in wheels/tires also does not affect true, wheel hp either, only the rate of change on the rollers and the vehicle acceleration on the road. One can only conclude that inaccurate moments of inertia and correction factors are being used.
On intercooled, turbo cars, there is usually insufficient airflow to ensure accurate results due to charge temperature variation which can be substantial. Even coolant temperatures may not stay down during the run which can affect power outputs considerably. The rate of acceleration is also important on turbo cars to be sure that the boost is not lagging the engine rpm. With RPM climbing too quickly, the boost has not reached a peak value so the hp figure is again inaccurate. Turbo cars should therefore be tested in top gear.
Without proper temperature stability and accurate moments of inertia on the rotating components, there CANNOT be accurate results as the scientific method is no longer being applied.
When all things are kept the same between runs and you get a tangible gain, it is a gain at least. How much, is open for discussion. It is important to note that as the oil temperatures in the engine, transmission and differential increase, friction usually decreases. This manifests itself as an increase in power at the rollers on each subsequent test. This factor should be accounted for when doing back to back runs. It may look like you are gaining some power on each run by making other changes when in fact this is due to reduced oil viscosity. When using a chassis dyno, always use the same gear and tires and wheels and start the runs from the same speed or RPM. Re-baseline periodically to see what temperature increases have done to power output.
Chassis dynos are quick and easy to hook up but have many of the above failings. They do not possess the accuracy of a properly calibrated engine dyno which has a more carefully controlled environment and condition set. Obviously, most non-professionals don't want to be yanking engines to use an engine dyno so chassis dynos do have their place.
Flywheel vs. Wheel HP
As most people know, there are power losses through the drivetrain so wheel hp is always lower than flywheel hp. Front wheel drive cars with transverse engines tend to be more efficient than most rear drive configurations due to the layout of components. However most publications overestimate these losses considerably.
Most rear drive cars have a 1 to 1, 4th gear which means that the power path goes directly through the mainshaft of the transmission. The only losses here are bearing drag which is less than 0.5% and the viscous drag of the gears running through the oil which is about 1% with hot oil. Indeed, published data indicates a transmission efficiency of 98 to 98.5% for conventional transmissions in 4th gear.
Losses within the driveshaft account for about 0.5% if they are properly aligned, balanced and with fresh U-joints.
Differential losses in the commonly used Hypoid type gearset is in the order of 6 to 10%.
The worst scenario case for a rear drive setup is on the order of 12.5% in 4th gear, not the 20 -25% often published. If 25% was being lost in the drivetrain, the oil would boil in the differential housing in short order and aluminum transmission cases would fatigue and break from the temperatures generated. On a 200 hp engine, something on the order of 37,000 watts would have to be dissipated out of the transmission and differential housings. Obviously, this is not the case.
Transverse, front drive transaxles usually have no direct lockup gears and no 1 to 1 ratio, however, since the torque path is never turned 90 degrees as in the rear drive setup and efficient helical gears are usually employed for the final drive set, losses are more on the order of 6 to 9 percent in the upper ratios.
Tire pressure and wheel alignment can have very significant effects on losses at the rollers. Tire pressures should be set the same between each test. Tire rolling resistance varies inversely with speed, another factor not taken into account by most chassis dynos when applying phantom flywheel hp formulas.
Comparing the Numbers
Many novices are quick to compare hp numbers between chassis and engine dynos and come up with all sorts of wild conclusions about drivetrain losses. These comparisons are essentially meaningless. Inertial dynos are based on the sound scientific priciple of accelerating a certain mass with a known moment(distance) over a given time. The rate of acceleration of that mass and moment is a result of the force applied (torque). If the RPM is known, HP can be calculated. On an inertial chassis dyno, it is virtually impossible to calculate the the moment of inertia of every tire, wheel, gear, joint , axle and shaft in the power train between the crankshaft and roller, therefore its results cannot offer an accurate HP figure. Even with coastdown drag measurements, these cannot be accurately calculated as different factors are affected in different ways. Some are proportional, some are inverse squared functions etc. Inertial engine dynos offer a very accurate figure if properly calibrated as only the flywheel's moment of inertia needs to be calculated and added to that of the billet. Water brake or eddy current dynos generally measure force (torque) directly through a ram or strain gauge so moments of inertia are not important on these in fully loaded tests.
Concluding that there was a 25% drivetrain loss by comparing HP achieved on an inertial chassis dyno and that obtained on an engine dyno is fundamentally flawed in that the chassis dyno numbers are highly suspect in the first place.
Other things to watch are correction factors applied for altitude, barometric pressure and temperature. These factors are NOT the same for atmo and turbo engines. Using atmo factors inflates the true, corrected HP figures on a turbo engine. In fact, look at the correction factor applied on your dyno sheets and see if they make sense. Many shady dyno operators simply enter a phantom correction factor to make the customer happy. This is a case where the dyno sheet DOES lie. Chassis dynos are essentially for tuning purposes, they are not well suited to giving an accurate hp figure.
04/28/02
One of my friends recently received a well known commercially available chassis dyno with both inertial and eddy current loading capability. When a different vehicle weight is entered in the software for a pull, the computer spits out a dyno sheet with vastly different hp figures. This is complete BS and shows that the software package is just plain wrong. HP did NOT change on the pull simply because a different weight was plugged into the computer. Take all these figures with a grain of salt.
Another SDS customer had his drag car chassis dynoed. It showed a max hp of 280 yet when the car weight, ET and trap speed were plugged in, these showed that around 500hp was required to achieve these results. The dyno figure was so far off, it was essentially useless.
10/31/02
Looking at the jagged, sawtooth "curve" that most chassis dynos produce is amusing. The torque and hp curves really don't look like this. This is a result of poor software or mechanical measurement in the first place. Torque does not go up down, up down 2-4 ft./lbs. over 50-100 rpm as any real engine dyno will prove. Chassis dynos are essentially tuning aids, not true hp measurement devices. Use them to dial in your EMS mapping, not to brag to your friend's that you made XXX hp. When he blows you away at the stoplight, you'll just look, just, well, uninformed.
Old Nov 4, 2003 | 09:32 AM
Blue Liquid's Avatar
Blue Liquid
Dude, everybody with a high chassis dyno is going to flame you.
Old Nov 4, 2003 | 10:48 AM
PoWeRtRiP's Avatar
PoWeRtRiP
I dont mind getting flamd a little so long as it serves a good purpose. The ones with the high chassis dynos are the exceptions rather than the standard. I see the occasional 255 hp stock dyno but i see many getting as low as 220-low 230. Im just trying to figure out where some of that power goes to before it hits the ground. Thx for that right up bbd its got some good stuff on it.
Old Nov 4, 2003 | 11:00 AM
dwnshift's Avatar
dwnshift
I am a going wiht the theory that the car is really only about in the 268-270 hp range and not 287 from what we have seen and heard.
Old Nov 4, 2003 | 12:11 PM
sschmuve's Avatar
sschmuve
Man...This sucks if it is true. I wonder if anybody will ever engine dyno our beloved 3.5 to see. Maybe Nissan would buy all our cars back like Mazda had to with the RX-8. Hmmm.
But...287 x .17 =48.79
287- 48.79 = 238.21
This seems about right.
Old Nov 4, 2003 | 05:49 PM
PoWeRtRiP's Avatar
PoWeRtRiP
thx for the comment dwnshift its nice to know im not the only one thinking this way. What im trying to figure out though is if the engine does produce 287 where does it go? Maybe more than avg gets lost on the z, has anyone done an engine dyno rather than a chassis dyno?
Old Nov 5, 2003 | 04:28 AM
dwnshift's Avatar
dwnshift
Yes we have had one of our engines on an engine dyno alone. When we first heard this we were pretty bummed because the series we are in we have to lobby for modifications for HP. They are basing the car on 287 HP as it is rated. The extra 17 or so HP that we think isnt really there we could sure use.
We have heard this rumor from alot of other resources also. I am sure Nissan got 287hp from one of these motors at some point or another.......maybe just not all of them.
Old Nov 5, 2003 | 05:21 AM
westpak's Avatar
westpak
SFZCC
I also think there is a difference from engine to engine. As it has been seen on some dyno days, some cars differ from 5-10 or so HP so it seems to be the luck of draw as to which one you get.
Old Nov 5, 2003 | 06:05 AM
Jun's Avatar
Jun
i dynoed at 235, that's with 1800 miles on the car, so i'm guessing i'm average? Does the car get better with more miles? I am like around 18% loss.
I guess it also depends on what type of dyno you test the car on.
Old Nov 5, 2003 | 12:08 PM
westpak's Avatar
westpak
SFZCC
See I dynoed at 240 so I paid a bunch of money for crap or I was behind to begin with. What was your max torque I had 239.
