a/c belt
Old May 25, 2010 | 04:26 AM
blueVQ's Avatar
blueVQ
Default a/c belt
So i tried to do a search for this and found nothing. i have changed my a/c belt 3 times in the last 10,000 miles and 2 times in the last 200 miles. Just wondering what would cause this or if this is a known issue with my car, its an 05 non rev-up. I have a vortech kit on it but i dont think that has anything to do with it because the first time it went i did not have the kit on yet. the belts are just coming off the pulley. Is my compressor bad and locking up? or is it just a problem with the pulleys themselves. I have personally looked it over and my performance shop i use has looked it over and neither of us could see anything wrong.
Old May 25, 2010 | 08:56 AM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
So the belt is coming off the compressor? Next time you have the belt off I would just try turning the compressor by hand and see if it turns nice and easy. Are you using a Nissan belt or an aftermarket one? Does it fit nice and tight once you snug up the tensioner?
Old May 25, 2010 | 10:35 AM
blueVQ's Avatar
blueVQ
yes everything fits nice and tight and seems to line up just fine. i just get the belts at the local parts store (napa, carquest etc.) i will check the compressor tonight i guess and see how easily that turns, that seems to be a good idea. anything else? i thought i heard something about problems with a/c belts a while back? not sure though.
Old May 25, 2010 | 12:08 PM
winchman's Avatar
winchman
Unless the ignition is on and the AC is on, the clutch on the compressor won't be engaged. If the clutch isn't engaged, the pulley will turn very freely.
You might be able to grip the part of the clutch that's connected to the compressor shaft tightly enough to turn it, but that might not tell you much about the compressor.
Is the AC working properly (putting out plenty of cold air) when the belt is in place? It it is, it's most likely not the compressor.
Old May 26, 2010 | 12:09 PM
blueVQ's Avatar
blueVQ
yes the a/c seems to work well when the belt is in place.. wtf now? im no racecar.. lol i would like to have some a/c ... lol ill throw one more belt on and have someone else turn the a/c on and have them tell me if it blows cold air while i watch it?
Old May 26, 2010 | 01:50 PM
Brett@AwesomeZ
Well, I would still check the compressor and make sure the grooved belt part spins freely and the front of it where the clutch is should be a little harder to turn but not exessive.
Old May 26, 2010 | 03:47 PM
05Z33's Avatar
05Z33
When you install the belt and apply tension to the pulley, do you also tighten the bolt that holds the tension pulley in place?
SonnyWu
Nov 24, 2015 08:19 PM
Vigman
Nov 17, 2015 04:34 AM
Fixxxercask
Nov 9, 2015 11:10 AM
Calinismo350z
Sep 14, 2015 04:04 PM
