taps for cleaning threads?
Old May 26, 2010 | 02:28 AM
scenehouser's Avatar
scenehouser
Default taps for cleaning threads?
hey guys,
i'm building an engine and need to clean out all the threads using bottoming taps.
can anyone tell me what sizes taps i need for the head bolts, main bearing caps and other holes?
thnx.
Old May 26, 2010 | 03:14 AM
DavesZ#3's Avatar
DavesZ#3
It's probably cheaper to buy a set then to buy individual ones for specific sizes.
Old May 26, 2010 | 03:55 AM
scenehouser
yeah i've been trying to find sets like that but without luck...
Old May 26, 2010 | 04:05 AM
adamc's Avatar
adamc
usually with taps your better off with indiv.
i really havn't seen many "sets" maybe a few generic ones
besides taps work in stages.. usually 2.. starter.. finisher.. and some i believe have even 3 stages..
so a set of just some standard sizes would be a lot of pieces. and probably be pretty expensive..
id recommend just buying the sizes you need
to figure out what tap sizes you need go by your desired/required bolt size.
I have provided you a chart that will tell you the size you need (be it that you know the bolt size)
http://www.imperialinc.com/pdf/I_Tap&DieChart.pdf
hope that helps
GL
Old May 26, 2010 | 08:19 AM
winchman's Avatar
winchman
I've had good luck with taps (and other items) from McMaster-Carr. They have all kinds in every size, their prices are reasonable, and they ship FAST. Every order I've placed with them has come the next business day with no extra charge.
_bit
Oct 2, 2015 07:49 AM
