Clutchless Shifting- opinions?
Old Jun 18, 2010 | 05:08 PM
Skv012a's Avatar
Skv012a
Default Clutchless Shifting- opinions?
What do you guys think about the technique if its done properly (no forcing the shifter if its not getting in/out of gear easily, no grinding, etc)?
I can't really believe that there is a horrible wear and tear on synchros by a technique that pretty much requires perfect/damn near perfect rev-matching.
Old Jun 18, 2010 | 05:15 PM
terrasmak's Avatar
I have a clutch and use it, no point not using it.
Old Jun 18, 2010 | 05:30 PM
HyperKnight's Avatar
HyperKnight
Stulax makes me cream
wat
Old Jun 18, 2010 | 05:31 PM
Skv012a's Avatar
Skv012a
Clutchless helps refine YOUR ability to rev-match, so in a sense its a very good teacher to learn your car's gearbox better, no?
Old Jun 18, 2010 | 05:58 PM
dkmura's Avatar
dkmura
General & DIY Moderator
No. Clutchless downshifts will put more wear and tear on the gearbox itself, particularly as you are learning. You're much better off spending your time learning to properly heel-and-toe downshift and rev matching while using the clutch. Plus, clutches are cheaper than rebuilding trannys.
Old Jun 18, 2010 | 07:40 PM
Zian's Avatar
Zian
Well if you get it perfectly right, not too much damage. But lets be honest, how often do you get it perfectly right? Heel-toe and proper rev matching will be much more useful. Have fun with it either way. Your car.
Old Jun 18, 2010 | 07:46 PM
0jiggy0's Avatar
0jiggy0
The GTR doesnt have a clutch pedal. Get one.
Old Jun 18, 2010 | 08:07 PM
And what would be the purpose of this technique?
Old Jun 18, 2010 | 08:16 PM
surfcity40's Avatar
surfcity40
poseurs pretending they are driving a race car. nothing more.
Old Jun 18, 2010 | 08:48 PM
OK. So this does not apply to me.
Old Jun 18, 2010 | 08:52 PM
03threefiftyz's Avatar
03threefiftyz
I have an expensive clutch........and I use it.
Old Jun 18, 2010 | 09:52 PM
kingjames23's Avatar
kingjames23
Ruins the entire experience of a sports car. You dont feel the same control...
Old Jun 18, 2010 | 10:08 PM
crsracing19's Avatar
crsracing19
clutchless shifting = auto tranny ????
Old Jun 19, 2010 | 05:16 AM
Swimminggerman's Avatar
Swimminggerman
this has already been debated.
Old Jun 19, 2010 | 05:18 AM
winchman's Avatar
winchman
I could do it pretty well on the '58 Ford school bus I drove when I was in high school. That's also when I learned it wasn't such a good idea.
Old Jun 19, 2010 | 11:54 AM
MDaniel22's Avatar
MDaniel22
I've done it a few times and not even realized until after that I did not engage the clutch. Just use your clutch or go get an automatic.
Old Jun 23, 2010 | 03:45 PM
willyumq's Avatar
willyumq
sometimes I do it on upshifts just to show off to my girlfriend (who is learning stick) but never tried downshifts.
Old Jun 23, 2010 | 10:30 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
For some reason the phrase "if you can't find it, grind it" comes to mind!
I think our synchros are fragile enough as they are, for you to go experimenting with clutchless shifting.
Old Jun 23, 2010 | 10:39 PM
ZKansasZ's Avatar
ZKansasZ
Old Jun 24, 2010 | 05:32 PM
ocdz's Avatar
ocdz
This isn't a semi truck your driving... the only proper time for clutchless shifts is with a dog box or constant mesh gearbox. Not to mention its much more cost effective to replace a clutch than rebuild a tranny. Like everyone else said you have a clutch, use it.
