Quick Seafoam question.
Old Jun 23, 2010 | 08:54 AM
djcetra's Avatar
djcetra
Default Quick Seafoam question.
Do I need to change the oil shortly after if I put it in through the brake line vacuum or is that only necessary if I put it in the oil itself?
What about if I put some in the gas?
I'm very suspicious of an exhaust leak and heard I would also see the smoke coming out other places if I used it. Car is almost at 58200 miles.
Old Jun 23, 2010 | 09:02 AM
quiksilver38's Avatar
quiksilver38
yes you will see white smoke coming out of exhaust leaks if thats what your asking, and you are supposed to change the oil if you do it in the vacuum line, putting it in the gas seems kinda pointless
Old Oct 27, 2010 | 07:40 AM
350sexZ's Avatar
350sexZ
can any one tell me were the brake vaccum line is located. the sooner the better thanks. or any vaccumm line good enough to put seafoam thru thanks
Old Oct 27, 2010 | 07:44 AM
06blueZ's Avatar
06blueZ
the brake vac line is on the passenger side of the plenum, and is the funny bent rubber line that goes into the battery area... you can use that or there is a smaller capped off port on the front left side.
I'd recomment using the smaller port because you will have less chance of stalling the motor. if you let too much seafoam in thru the brake port, it could even hydrolock...
Old Oct 27, 2010 | 08:09 AM
350sexZ's Avatar
350sexZ
thanks alot im about to change my oil and throw some seafoam in thanks alot
Old Oct 27, 2010 | 08:22 AM
TheDangerZone's Avatar
TheDangerZone
This stuff is good. A lot of the claims for results are true. Just have to deal with the white smoke for a little.
Old Oct 27, 2010 | 06:40 PM
shiftdrift06's Avatar
shiftdrift06
Just have one guy slightly rev the engine. and you control the flow of the suction.
Pour the seaform in a visible container, and also as stated use the smaller vacuum port on the left intake manifold. it is capped off, place a vacuum hose on it.
Change the oil after you ran the car for awhile.
Old Oct 27, 2010 | 07:03 PM
zaperroni's Avatar
zaperroni
i used the brake vac line on the driver side as seen in this vid:
http://www.youtube.com/watch?v=Csq4LSIB5ok
lapham3
Oct 7, 2022 03:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
_koubie_
Sep 20, 2015 06:34 PM
