Water in my Gas>?
Old Oct 25, 2010 | 03:46 PM
gsxtrex's Avatar
gsxtrex
Default Water in my Gas>?
I've had my car out of commision for about a year and I finally went to start it today and its popping and such. The same gas has been in the car for about that amount time. Assuming the car has water in the tank, anyone have any suggestions on what steps to take ?
BTW, I did alot of searching and didn't find anything.
Thanks Troy
Old Oct 25, 2010 | 03:48 PM
calin's Avatar
calin
Doesn't the gas tank build up water condensation on cold days? I'm guessing since the car sat for that long without being started, it build up quite a bit of water in the tank. That's just my guess.
Old Oct 25, 2010 | 04:05 PM
KornerCarver's Avatar
KornerCarver
Did you put Stabil in the tank when you stored your car? If not, I suspect you may have varnish deposits built up in the injectors. You will probably need to have the injectors professionally cleaned.
Old Oct 26, 2010 | 10:09 AM
rcdash's Avatar
rcdash
Fill up the tank with some good gas. Add some octane booster (heet) if you need to. I think it'll be fine.
Old Oct 26, 2010 | 10:41 AM
Gingervitis526's Avatar
Gingervitis526
How much gas was in the tank when it was left sitting? If it was a full tank then there wouldnt be much room for condensation to form.
Old Oct 26, 2010 | 10:43 AM
terrasmak's Avatar
Top off with fresh gas, see how it run. It should/may clear out.
Old Oct 27, 2010 | 07:52 PM
gsxtrex's Avatar
gsxtrex
Thanks guys. I plan on adding some unleaded 100 to fill it up and the octane boster + heet. I had about 3/4 of a tank when I stored it so there may have been room for it fill up.
etkms
Jun 19, 2022 06:30 PM
350z82
Oct 1, 2015 06:25 PM
roadmax
Sep 12, 2015 05:55 PM
PureR3d
Sep 10, 2015 06:23 PM
