Possible misfire?
Old Jul 19, 2010 | 11:59 AM
DB350's Avatar
DB350
Default Possible misfire?
Recently i've noticed that my car has what I believe to be a misfire. At idle I notice what sounds to be like a clunking sound or a low pop, and a family friend who's a very good mechanic took one listen and said probably just a little misfire, which is probably just cause from a bad spark plug, etc. Do you guys have any other ideas before I start pulling things off and out?
Car is 100% stock btw
Old Jul 19, 2010 | 12:08 PM
BonesZ33's Avatar
BonesZ33
an actual missfire would cause a CEL.. P0301 cylinder 1, p0302 cylinder 2, p0304 cylinder 4, etc
Change the spark plugs.. Its probably time anyways, It takes about an hour of time
Old Jul 19, 2010 | 12:11 PM
DB350's Avatar
DB350
Yea that's why I wasn't 100% sure, cause I did a search and they all threw CEL's.
Recommendations for new plugs? I know that some cars don't like certain compounds (iridium, copper etc)
Old Jul 19, 2010 | 12:18 PM
BonesZ33's Avatar
BonesZ33
coppers have the best eletrical properties and are the cheapest.. the down side is that they don't last as long as others..
iridiums are second best conductors, and last the longest, and are more expensive..
I like buying coppers and changing them often, but thats just me.
NGK's are my brand of choice, and they come pre-gapped
Old Jul 19, 2010 | 02:25 PM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
Yup. PLFR5A-11 is the stock plug and works great until you start adding boost or spray. $66 a set from the dealer
Old Aug 4, 2010 | 08:49 AM
DB350's Avatar
DB350
UPDATE:
Changed the sparks, and yesterday the SES light came on so i plugged in a friends checker and got cylinder 2 misfire
suggestions on where to go from here?
Old Aug 4, 2010 | 09:46 AM
Brett@AwesomeZ
Check for spark and fuel, go from there.
Old Aug 4, 2010 | 12:59 PM
XxKwestxX's Avatar
XxKwestxX
Check the spark plug connector and make sure there is no corrosion, dirt, oil, or maybe even a pushed pin. If all that is good, try swapping out coils with another cylinder and see if the problem follows the coil or stays with the same cylinder.
lowtempo
Jun 25, 2025 11:47 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
sccoupe
Jun 5, 2006 08:01 AM
sentry65
Jan 14, 2005 08:51 PM
350Zzzz
Dec 16, 2003 08:12 PM
