How can I clean injectors b4 I install them?
Old Aug 12, 2010 | 02:42 PM
zcar03's Avatar
zcar03
Default How can I clean injectors b4 I install them?
I'm strapped for time so I can't send the injectors out to be cleaned. How can I clean them before I install them. They are 600cc Deutchwerks injectors. Thanks
Old Aug 12, 2010 | 02:49 PM
Nexx's Avatar
Nexx
Removal and Cleaning
This is not really an option open to the do-it-yourselfer because it requires special equipment that can cost anywhere from $4,000 to $8,300. Because of that and the labor involved, a shop may charge you $40+ per injector for removal and cleaning. (Makes you long for the good old days of carburetion, doesn’t it?)
But it’s a lot cheaper than spending at least twice that to replace ruined injectors with new ones, which is what happens when an injector becomes hopelessly clogged. And injectors can be tested, observed, and compared off the car. An injector that’s not passing as much liquid as the others can be re-cleaned. If that doesn’t work and the injector must be replaced, the injector that needs to be replaced is easily pinpointed.
Old Aug 12, 2010 | 03:50 PM
zcar03's Avatar
zcar03
Wondering if anyone local in ma or nh can dont it. How can I test them.
Old Aug 13, 2010 | 02:48 PM
superchargedg's Avatar
superchargedg
Damn Noobs
^^^You cant
seagrasser
Oct 11, 2015 03:27 PM
nanotech
Oct 2, 2015 05:02 AM
