New Clutch Kit Installation
Old Aug 12, 2010 | 08:32 PM
leeys90's Avatar
leeys90
Default New Clutch Kit Installation
Hi guys,
I am going to change my OEM clutch to NISMO clutch kit. I send my car to the workshop just now and the mechanic told me it's an easy task for them. Just they worried that after disconnected the wires from the transmission will make the "setting" gone. I think they are referring to ECU setting?
Therefore, they asked me to do a research on this issue first before they get the work started. Oh yah, I almost forgot to mention that I am from Malaysia, where the place with less professional mechanic.
Thanks everyone.
Old Aug 12, 2010 | 09:12 PM
diablox1's Avatar
diablox1
maybe im dumb, but i dont see any issues with any "settings" due to replacing a clutch.
Old Aug 12, 2010 | 09:26 PM
JasonZ-YA's Avatar
JasonZ-YA
disconnect the battery first, just as general practice.
removing all the sensors from the tranny wont do anything at all. just dont damage or break them of course.
also, note that the flywheel "if your swapping that" also only goes on a certain way. ensure you match the dot that is between the T55 torx bit holes to the dot on the aftermarket flywheel...
if not installing an aftermarket fly, then ignore that
-J
Old Aug 14, 2010 | 03:21 AM
leeys90's Avatar
leeys90
Thanks so much for the replies.
I got the clutch kit installed and it works like a charm
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
