Clutch Recommendation??
Old Aug 21, 2010 | 12:37 PM
huanandonly's Avatar
huanandonly
Default Clutch Recommendation??
Can anyone recommend a good after-market clutch?... and do you need to have a lighter flywheel combo? ...or can you keep the stock flywheel and just replace the stock clutch alone? I want to avoid the noisy rattle at low RPM's. btw, no track days...just looking for something of an upgrade to the stock clutch. Thanks!
Old Aug 21, 2010 | 12:50 PM
Plenty of recommendations and discussion here. Read.
If the clutch looks like this it will mimic OEM performance.
If the clutch looks like this you may want to skip it.
Old Aug 21, 2010 | 02:53 PM
huanandonly
thanks Davidv.... how about the second part of my question....do you need to have a lighter flywheel combo? ...or can you keep the stock flywheel and just replace the stock clutch alone? I know its probably better to have the combo...but i really want to avoid that rattle. Any suggestions? thanks!
Old Aug 21, 2010 | 03:09 PM
0jiggy0's Avatar
0jiggy0
You dont have to replace the flywheel if all you want is a clutch with a slightly better grab.
Old Aug 21, 2010 | 03:49 PM
huanandonly
Any idea of how much it cost to have the clutch put in these days on a 2007? Just so i have something to judge by when looking for a shop...thanks!
Old Aug 21, 2010 | 04:23 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
RPS stage 1 clutch flywheel combo
Old Aug 21, 2010 | 07:31 PM
You may want to check the OEM flywheel for wear. Here is a clutch-flywheel combination from Competition Clutch. About $924.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
