Cheap Spike grounding kit from eBay - results
Old Nov 12, 2003 | 06:05 PM
dchengmd's Avatar
dchengmd
Default Cheap Spike grounding kit from eBay - results
Just thought I'd share my impressions after installing a cheapo grounding kit purchased on eBay.
I recently bought the Spike "Circle Earth System" set of blue colored grounding wires for $18 plus $13 FedEx overnight shipping. This is the set that many of you probably have seen around on various websites. It comes with a set of 7 heavy-duty (looks to be 4 guage) wires of different lengths, a battery terminal adapter, brackets, and a bagful of nuts and bolts. I'd never heard of the Spike brand, so I took a good look at the package - lots of Japanese lettering.
Following the instructions for a standard 5-wire ground install, I was able to complete the job in about 40 minutes. There was no problem with the lengths of the wires - everything fit fine and the included bolts match perfectly with the grounding points on the Z.
There is quite a noticeable difference in the 'feel' of the engine after the kit is installed. The idle is much, much smoother and throttle response just feels more responsive.
So far, so good. If anyone's looking for a nice, inexpensive mod, I highly recommend installing a grounding kit. The difference in engine feel is quite impressive. If you're averse to paying a lot of $, you can get what appears to be a fairly decent kit for about $20 off eBay.
Old Nov 13, 2003 | 02:34 AM
teh215's Avatar
teh215
Thanks for the tip. I checked out the auction and I have a question. Where does that disc go that all of the wires attach to?
Old Nov 13, 2003 | 04:56 AM
dchengmd's Avatar
dchengmd
I didn't use the disc. I wired everything up in serial, like how everyone else has been (check other threads for how to do this).
If you do want to use the disc and wire everything in parallel, the disc connects to the negative terminal of the battery. In the Z, it'd look pretty ugly, with all those wires going under the battery cover.
Old Nov 13, 2003 | 05:28 AM
teh215's Avatar
teh215
Thanks, I think I'll pick one up. For under $20 what have I got to lose. I just couldn't bring myself to spend the $75 or so other vendors are asking for 5 pieces of wire.
Old Nov 13, 2003 | 05:57 AM
reiver's Avatar
reiver
Default Re: Cheap Spike grounding kit from eBay - results
Thanks for checking this out bro!
Old Nov 13, 2003 | 06:03 AM
bhk1004's Avatar
bhk1004
cant find the grounding kit on ebay...? maybe im looking for the wrong thing?
Old Nov 13, 2003 | 06:35 AM
teh215's Avatar
teh215
This the one that I found: http://cgi.ebay.com/ebaymotors/ws/eB...tem=2442760473
Here is a pic:
Old Nov 13, 2003 | 11:21 AM
jabroney12's Avatar
jabroney12
Can you elaborate on smoother idle and the faster throttle response. IS that saying that the when the car on idle would vibrate and and the gears arent as reponsive before?
Old Nov 13, 2003 | 11:27 AM
vfr350's Avatar
vfr350
I have had a grounding kit for quite sometime. Does it actually help??? That is really a good ? I could see this helping older cars with corrosion but nothing noticable on a new z.
Old Nov 13, 2003 | 11:33 AM
yobri's Avatar
yobri
Thanks for the report doc. Posts like this make visiting online forums valuable.
Old Nov 13, 2003 | 09:39 PM
dchengmd's Avatar
dchengmd
I'm afraid I don't have any actual numbers to back up what I'm saying, so take my words with whatever grains of salt you're willing to spill.
Before I installed the kit, I noticed that when stopped at a light I could feel the engine stutter slightly, and the tach would display a fluctuation in the RPMs over about a 250 to 500 RPM range. After the kit was installed, this fluctuation has disappeared, or has decreased to a range where I don't 'feel' the stuttering anymore. The engine just feels smoother overall. When accelerating, the power band appears smoother as well with better, more immediate starts.
I don't see much difference when revving high or at high speeds, but at lower RPMs there is definitely a difference.
All this is purely anecdotal, so if you don't believe what I'm saying, that's fine.
Old Nov 13, 2003 | 09:41 PM
dchengmd's Avatar
dchengmd
That's exactly how I felt. The kit was only $18, and the install is completely reversible, so I thought I'd take the small plunge and give it a shot.
So far, this cheapo kit appears to be working well (the one you pictured is the one I bought, BTW).
Old Nov 13, 2003 | 09:42 PM
dchengmd's Avatar
dchengmd
You're welcome. Give it a try if you haven't already
Uriyo_
Sep 8, 2021 08:46 AM
sales@czp
Sep 23, 2019 03:30 PM
