Grease coming out from rear axle
Old Sep 7, 2010 | 09:24 AM
koren's Avatar
koren
Default Grease coming out from rear axle
Hi!
My left side of the Z got hit in both wheels. I fixed the suspension but now I see that the grease start coming out of rear axle. Boot is not damaged or anything and seems like grease going through the boot connection with the axle shaft.
Should I remove the boot, add grease and seal back again?
Or may be my axle got hit and I need to change it?
Old Sep 7, 2010 | 09:44 AM
Nexx's Avatar
Nexx
rear differential bushing sounds like. spl makes them.
Old Sep 7, 2010 | 09:58 AM
JasonZ-YA's Avatar
JasonZ-YA
^ from the sound of things, its the axle - got damaged.
I would remove the axle and inspect it well......post pics and we can probably help a bit more..
-J
Old Sep 7, 2010 | 11:52 AM
koren's Avatar
koren
will do on the weekend! Thanks
Old Sep 7, 2010 | 12:35 PM
winchman's Avatar
winchman
Isn't the boot is on the rear drive shaft CV joint? The rear axle itself has a regular grease seal.
Old Sep 19, 2010 | 11:55 PM
koren's Avatar
koren
Uninstall the axle, it was damaged.
First, it was a hole in the boot (the one close to the wheel), little one, hard to see.
And the other side was damaged also...
Replaced the whole axle + the bearing (it was bad also - http://www.youtube.com/watch?v=-6OvaQvAgAk)
Still, here some weird sounds from the drivetrain, couldn't specify where from exactly.
I guess I'll have to drive fro a little while to find out.
Old Sep 20, 2010 | 12:07 AM
JDMStanced's Avatar
JDMStanced
never seen grease on there
Old Sep 20, 2010 | 09:29 AM
koren's Avatar
koren
That happens probably when axle hit differential box, so the little metal cover of the axle bending and popping up.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
samansharif
Sep 25, 2015 12:31 PM
