Sikky 350z/G35 LSX swap
Oh I know they do. But two major things stand in the way of buying from them:
1. They have a track record almost as bad as AAM on this site; orders are never complete and often have completely wrong items included. Their customer service is reminiscent of trying to get anything done by any employee of the state of maryland. No, scratch that, Maryland is easier to deal with.
2. Sikky is local.
2. Sikky is local.
Vendor - Former Vendor
Excellent clearance
Oil filter relocation lines
Aluminum drive shaft installed
front end of drive shaft
Dipstick installed with bracket
Bottom view
Sikky billet short throw shifter, standard with mount kit (over $550 value)
bottom of shifter, complete housing machined from one piece of billet aluminum
factory shifter placement, with threading for factory 6 speed **** Super Clean!
factory fit, ultra low engine placement= low center of gravity
almost done.
Here is a link to the listing on our site with price
http://www.sikky.com/view_item.php?id=27&catid=12
So the big question is how about the A/C? Does it work will it work. Speedometer and tach can be swapped in the cluster that does not bother me. But being in the desert I would need and want a/c. Swap the nissan compressor on the ls or use the ls tied into the nissan lines? I would also want the truck 6.0 liter with a 4l60e. Because im cheap. Will your headers work on the truck 6.0 or 5.3 heads?
The truck motor will work, the trans bracket we currently offer in the kit is for the T56 only. We should have a bracket done for the 4160e in about a month.
We would need someone to test the header fitment with the 5.3 heads on a 6.0, don't know if we have tested that combo but odds are good it will fit.
