Which stock fuel lines to replace to run E85?
Old Sep 20, 2010 | 11:33 PM
Andrei's Avatar
Andrei
Default Which stock fuel lines to replace to run E85?
Does anyone know which lines exactly need to be replaced to run E85 on a stock fuel system? I want to run E85 naturally aspired and tune using Uprev Osiris.
The FSM simply says "tube" or "line." Does not say what it's made of.
Old Sep 23, 2010 | 10:26 AM
Sylvia Zcarr's Avatar
Sylvia Zcarr
Why? The E85 only benefits (perf-wise) the boosted bubbas...
You need new injectors and pump. Metal lines are fine - only hoses may need to be swapped.
Old Sep 23, 2010 | 10:58 AM
ndilo21's Avatar
ndilo21
Probably because it's cheaper.
Old Sep 23, 2010 | 12:33 PM
djamps's Avatar
djamps
It can help NA tuning as well... 100 octane helps when you're pushing timing to the limit. The loss in mileage pretty much defeats the cheaper price though.
I'd also be interested to know what has to get replaced for E85. Surprised there's no threads about this.
Old Sep 24, 2010 | 08:20 PM
omsin523's Avatar
omsin523
its a big thing on the evo forums
Old Sep 25, 2010 | 02:23 AM
WTFMike's Avatar
WTFMike
My neighbor just changed his 450 hp srt-4 to E85. He told me he added a bosch 044 inline pump and surge tank. Obviously, he also went with bigger injectors. I believe he is still running stock fuel lines for the most part. He has me starting to consider switching my car to E85. I am going to start looking into it.
Old Sep 27, 2010 | 09:28 AM
hellsoldiers08's Avatar
hellsoldiers08
Proedi128 something something they use it on a supra and recently on a 350z . It allows you to use both gas and e85 and the program does all tha stuff. Like you can have a quarter e85 and have 1/2 gas. And you can still run the car:0)
Old Sep 27, 2010 | 11:00 AM
str8dum1's Avatar
str8dum1
dont need to replace anything. stock lines are all coated so they are fine
Old Nov 7, 2010 | 04:16 AM
Andrei's Avatar
Andrei
Turns out it is true. Maybe a benefit of Renault and Nissan working together in Brazil?
I ran it for 3 days straight with the only problem being a lean condition on bank 2. Could have been caused my a vacuum leak. Osiris will take care of adding more fuel soon.
Should be a nice power increase running aggressive timing.
The low MPG and low price comes out to about the same as running 93 octane. BUT E85 is US made and makes more power from tuning.
Old Nov 7, 2010 | 11:53 AM
biggersNISMO's Avatar
biggersNISMO
Curious to see if any NA Z's have seen results from switching to E85
Might not be much of a "gain" but it's another option.
bcoffee20
Nov 19, 2015 06:39 PM
seagrasser
Oct 11, 2015 03:27 PM
FromGtoZ
Sep 20, 2015 03:41 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
