Slight Idle/load Issue
Old Sep 24, 2010 | 09:27 PM
carlos305's Avatar
carlos305
Default Slight Idle/load Issue
Sup guys,
I'm having a slight issues with my z, its not really a big problem but i want to fix it before it gets worst. When i'm on idle , i feel a slight hiccup every like 2-6 seconds where the rpms drop slightly , also when i put the car under load i feel like it stutters a bit(kind of when nitrous kicks in, but not as strong) Could this be a bad plug?
EDIT: only mod is 5/16th spacer and -2 degrees retarded.
Old Sep 25, 2010 | 02:53 AM
winchman's Avatar
winchman
It's just getting groggy when the nitrous kicks in. It affects me the same way.
Old Sep 25, 2010 | 04:36 AM
carlos305's Avatar
carlos305
The car is no longer on nitrous, it only has a spacer and retarded timings.
Old Sep 25, 2010 | 09:33 AM
209Z33's Avatar
209Z33
maybe small vacuum leak
Old Sep 25, 2010 | 11:43 AM
djamps's Avatar
djamps
I always had a slight misfire at idle when I was stock/untuned. I wouldn't worry about that. Try returning your timing to stock and see if it helps.
Old Sep 25, 2010 | 03:55 PM
Zero260's Avatar
Zero260
I get a funny sounding blip every 2-3 sec at idle, but my rpms don't drop. but I'm also APS tt'd...I don't worry about it.
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
