Did I make a mistake opening the VTC spockets?
Old Nov 5, 2010 | 08:21 AM
GT-ER's Avatar
GT-ER
Default Did I make a mistake opening the VTC spockets?
I was disassembling my engine and got caught up and loosed all 4 bolts on the VTC sprocket and the lid popped up ( although it was not removed ). I then realized that I wasn't supposed to remove those bolts according to the manual and tightened them back with my fingers but have yet to torque them.
Did I mess something up by doing this? Or does the manual say not to do it because it's just not necessary?
Old Nov 5, 2010 | 10:03 AM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
Not supposed to take them apart. I remember someone I used to work with did that and couldn't get it back together properly. Good luck.
Old Nov 5, 2010 | 11:43 AM
GT-ER's Avatar
GT-ER
I noticed it had some small parts inside but they never came out since I only separated the lid slightly and I closed it back up pretty effortlessly.
Old Nov 5, 2010 | 12:41 PM
Nathan's Avatar
Nathan
There is no mystery with the internals of the VTC sprocket.
Just a rotating vane assembly, a spring with a plastic one end & a small steel rod on the other.
This steel rod (piston) stops the vane from rotating on cranking & is lifted away by oil pressure when the motor starts.
If the motor is a high mileage unit & had poor oil maintenance a varnish can build up inside so it is a good idea to pull them apart & clean up.
Old Nov 5, 2010 | 02:47 PM
GT-ER's Avatar
GT-ER
It has 85K miles but the motor inside is VERY clean. So you would say that I'm okay?
Old Nov 6, 2010 | 12:36 PM
Nathan's Avatar
Nathan
Yes you will be OK, but really there is no big deal about taking the cover plate off to have a look. It,s pretty simple inside with nothing you can do wrong.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
