Clutchmasters fx300 issue
Old Nov 8, 2010 | 02:21 PM
joeldogg1's Avatar
joeldogg1
Default Clutchmasters fx300 issue
2006 350z GT Installed new clutchmasters fx300 clutch kit and alum. flywheel, perfect fit. When clutch pedal is pressed slave cyl gets full stroke, release arm does not travel enough to disengage clutch completly. Master, slave, line all new & worked fine w/ oe clutch. New pressure fingers measured 3/16" shorter than stock. seems to need more stroke... Ideas?
Old Nov 8, 2010 | 06:39 PM
hellsoldiers08's Avatar
hellsoldiers08
could it be that the fingers measure 3/16 shorter than stock??Maybe it a lot more when added up, like that could make all the difference.
Old Nov 9, 2010 | 04:40 PM
joeldogg1's Avatar
joeldogg1
Yes I'm aware this is the difference. What I'd like to know, is there anyone out there who has encountered this same problem? If so what was done to correct it? Anyone heard of a shim or certain part available? Manufacturer claims there is not and should work as is. I've read a couple other threads, there were other types of vehicles with the problem, however no resolution posted.
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
