4.083 install troubles...diy gurus help
Old Nov 12, 2010 | 02:41 AM
KTran's Avatar
KTran
Default 4.083 install troubles...diy gurus help
i wanted to get some feedback from someone who actually installed the 4.083 ring and pinion gears onto the 350z's differential.
Please, only reply if you've installed this FD personally or experienced the install hands on
I currently have my differential with a good mechanic friend that's installing my 4.083 gears, but he's having trouble.
I ordered BNIB nissan frontier 4.083 ring and pinion gears, bnib side and pinion seals, and bnib crush sleeve. My installer said my bearings were still good so we reused them; he measured and shimmed the differential accordingly. The trouble he's having is when everything is bolted together, the ring gear would not touch the pinion gear at all. There is about a 1/4"-1/2" of an inch gap between the pininion ring gear. My installer tells me that he think something is missing on the pinion gear...
i've been lookin at rear end diagrams and cant seem to find what's missing...
frontier rear
350z base(non lsd) rear
from cross referencing both diagrams...all these parts are the same on both vehicles:
spacer housing
pinion bearing
bearing caps
side bearings
only thing i see different is on the fronther, the spacer housing part # is 38165, but on the z, the spacer housing part # is 38165M...would the "m" part matter at all?
well, can anyone chime in and help me?
any input would be greatly appreciated.
thanks
Old Nov 12, 2010 | 03:08 AM
0jiggy0's Avatar
0jiggy0
Crush sleeve on the pinion gear.
Old Nov 12, 2010 | 03:18 AM
KTran's Avatar
KTran
i have one of those, brand new
with it installed, it still doesnt take up the slack
Old Nov 12, 2010 | 03:34 AM
0jiggy0's Avatar
0jiggy0
I did the install like 9 months ago but I remember the only thing besides the bearings in there was the crush sleeve. 1/4"- 1/2" is a lot in there, there has to be something missing. Stupid question Did he press on the bearings all the way?
Old Nov 12, 2010 | 04:45 AM
KTran's Avatar
KTran
i'd assume he did...
i can ask him later today
Old Nov 12, 2010 | 08:52 AM
tylerxfire's Avatar
tylerxfire
a rear end is a rear end..obviously he is not very experienced as he or u said he is...
Old Nov 12, 2010 | 10:56 AM
KTran's Avatar
KTran
I guess people don't know how to follow rules...lets get back on topic
which spacer housing(crush sleeve) do you guys order?
the one i ordered is nissan part#38165-0C020
Am I suppose to use the spacer housing(crush sleeve) from the 350z or frontier?
Old Nov 12, 2010 | 12:08 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
perhaps you're not using a manual transmission differential
Old Nov 12, 2010 | 07:42 PM
KTran's Avatar
KTran
dam...
i really dont know if my diff is from a 5at or 6spd since it was purchased off of ebay. After reading your reply, I went ahead and emailed the seller to see if he can clarify which one i have.
also, just in case the seller ignores me and i'm effed, i read here that I can count the teeths on the original ring gear and determine if i have an auto(47) or manual(46) unit; how true is that post?
Old Nov 12, 2010 | 10:19 PM
KTran's Avatar
KTran
FML
the ebay seller confirmed that its from an 5at...
well, looks like i'll have to find an 6spd diff
thanks for all the replies
Old Aug 19, 2011 | 08:49 AM
6MTkeith's Avatar
6MTkeith
*Back from dead*
Something else is wrong here. The Auto and manual rear ends will accept the same gear sets. *Correction. 3.5 gears fit in 3.3 pumpkins with a 10mm spacer, but 3.3's need to be mounted on a machined vlsd diff. I have a 3.7 gear set from an auto g37 non lsd diff and my 6mt vlsd 3.5 gears are in a 5at G35. You mechanic has done something wrong or you got the wrong gear set. Turbo guys put 5at 3.3 gears in 6mts all the time.
OP, post your findings and or solution. I hate when people ask for help and then abandon threads after they figure it out without posting the solution.
Old Aug 19, 2011 | 09:07 AM
Z1 Performance
Former Sponsor
Originally Posted by 6MTkeith
*Back from dead* Something else is wrong here. The Auto and manual rear ends will accept the same gear sets. I have a 3.7 gear set from an auto g37 non lsd diff and my 6mt vlsd 3.5 gears are in a 5at G35. You mechanic has done something wrong or you got the wrong gear set. Turbo guys put 5at 3.3 gears in 6mts all the time.
turbo guys who put 3.3 final drives in their manual cars all the time are also swapping differentials to either a stock, or aftermarket one for a manual transmission car.
Old Aug 19, 2011 | 09:37 AM
6MTkeith's Avatar
6MTkeith
Corrected. Thanks for confirming that.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
