Engine Exploded
Old Nov 17, 2010 | 04:02 PM
mattyg50's Avatar
mattyg50
Default Engine Exploded
I have a friend that owns a 2004 350z that says while he was driving around 40mph, the engine started to smoke and make noise, he shut it off, than restarted and it would not start. after getting it to the shop, the removed the engine, the rear piston, on both sides, was gone!!! it look like it blew apart, the rods was there but no rear piston!! it broke the camshaft in half, bent valves, how can this happen, or if someone has seen this, can tell me what happened??? i find it hard to believe just driving at 30-40 mph and the pistons exploding can do this??
thanks for any help or thoughts!!
Old Nov 17, 2010 | 04:13 PM
DavesZ#3's Avatar
DavesZ#3
No oil in it?
I'm sure there's a whole lot more to this story than "I was just driving around at 40mph and my engine blew up".
Did he forget to shift out of first gear?
Old Nov 17, 2010 | 04:26 PM
zer0cool's Avatar
zer0cool
Don't see much of a point in this thread. The guy mustve had some type of oil pump failure or no oil as stated above. Either way, wondering why won't bring the motor back.
Jus saying.
Old Nov 17, 2010 | 05:12 PM
mattyg50's Avatar
mattyg50
just trying to see if anyone else had this issue, it did have oil, only reason i am saying this is because none of the parts are blue in color, but it could of been a oil issue. i may have to agree with the no shift issue, it is a manual, is there anyway of checking the computer missed shifts???
thanks again!
Old Nov 17, 2010 | 05:18 PM
GT-ER's Avatar
GT-ER
Was this vehicle stock?
Old Nov 17, 2010 | 05:22 PM
djamps's Avatar
djamps
Rear pistons run hottest since they don't get as much coolant. I wonder if he overheated the crap out of it, blew a headgasket and kept driving...ect...
DavesZ#3's Avatar
DavesZ#3
The amount of damage you describe sounds like something broke loose at a very high RPM, or lots of power was being generated.
Surely the mechanic that opened it up has a better idea of what might have caused it.
As for this happening to anybody else - sure, just check the FI section, it's full of blown engine stories.
Old Nov 17, 2010 | 05:25 PM
huyrua's Avatar
huyrua
Are you sure it's not your car? Got pics of damage?
Old Nov 17, 2010 | 06:13 PM
mattyg50's Avatar
mattyg50
thank you!! that is some great info!!
Old Nov 17, 2010 | 06:15 PM
mattyg50's Avatar
mattyg50
LOL!! no my car has only 6500 miles on it, she still is getting broke in. i can upload a pic tomorrow!!
Old Nov 17, 2010 | 06:17 PM
Ronin82's Avatar
Ronin82
Old Nov 17, 2010 | 06:27 PM
mattyg50's Avatar
mattyg50
Originally Posted by Ronin82
LOL!! I will have the pics in the am!!! thanks!
Old Nov 17, 2010 | 07:26 PM
"My friend" threads are not allowed. Check rule #9.
Old Nov 17, 2010 | 08:56 PM
R3belzBRN's Avatar
R3belzBRN
hahaha lols... nice one davidv
Old Nov 17, 2010 | 09:45 PM
Ghalleo's Avatar
Ghalleo
LMAO
Old Nov 17, 2010 | 10:01 PM
winchman's Avatar
winchman
"Rear pistons run hottest since they don't get as much coolant."
They get just as much as any other part of the engine. I'd say the Nissan designers are probably capable of designing the cooling system so there are no hot spots that would lead to catastrophic failures. Coolant passages can be designed to direct the flow where it's needed. It's not as simple as "in the front and out the back".
I'd like to know more about how the car was driven and maintained. I bet there was some serious abuse or neglect going on.
Old Nov 18, 2010 | 03:26 AM
DavesZ#3's Avatar
DavesZ#3
OP - were you riding in the car at the time of the failure? I'm guessing not. Without accurate info on how the car was maintained, if it was abused, prior signs of problems and a description of the actual failure, this whole thread is pointless.
Unreliable third party speculation is not going to find the answer - this will become another internet urban legend.
Old Nov 18, 2010 | 04:56 AM
RandomHer0's Avatar
RandomHer0
I lol'd at "Exploded".
Old Nov 18, 2010 | 05:03 AM
roger22's Avatar
roger22
FAIL......................
Old Nov 18, 2010 | 05:17 AM
mattyg50's Avatar
mattyg50
