Clutch Issue yet again
Old Dec 5, 2010 | 12:08 PM
BristishZ's Avatar
BristishZ
Default Clutch Issue yet again
Okay guys, its been about 4 months since my clutch install and im still having problems.The clutch doesn tslip waht so ever, but if i take my foot off the clutch while in netural at anytime while driving, its near impossible to get the car back into gear again. I think its the slave cylinder not dissengaging from the flywheel properly. last time about a month ago i bleed the slave and it had a lot of air in it. But while driving the car its fine, sometimes its rough shifting between gears but other times its very smooth. any ideas or has anyone had the same problem? i oredered a new slave cylinder and does anyone have an effective way of bleeding that *****. i think the problem with the old one was its took me like 2 hours to bleed, and opening and shutting it so much must have scored the seat and now it leaks air. Thanks Ben
Old Dec 5, 2010 | 12:57 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
get yourself a factory service manual and follow the procedure for R&R of the slave, as well as resetting the free play for the pedal
Old Dec 5, 2010 | 02:18 PM
BristishZ's Avatar
BristishZ
i have a service manual and have even had a nissan tech come over and look at it. We have bleed it the proper way but theres a loop that traps alot of air. i have replaced the slave once before but the engaging gear problem kept getting worse.
Old Dec 9, 2010 | 11:25 AM
DaveSB's Avatar
DaveSB
Update on your car? It definately sounds hydraulic.
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
