Wideband oxygen sensors
Old Nov 20, 2003 | 04:06 PM
MSGarrett1's Avatar
MSGarrett1
Default Wideband oxygen sensors
I am just curious, how many of you guys and gals out there have a wideband oxygen sensor? Where did you purchase yours? Where/how did you have it installed? How are you utilizing this tool?
Old Nov 20, 2003 | 04:12 PM
jesseenglish's Avatar
jesseenglish
I got one. Purchased it from http://www.wbo2.com
Here's a thread I did about mine.
http://www.350zfrenzy.com/forum/show...&threadid=2287
The beauty of this setup is that it also enables logging of up to 3 EGT inputs, A/F ratios and several user programmable inputs. For example, I'm currently logging, A/F ratios, RPM and boost, eventually I want to also log Fuel Pressure and Throttle position. I just haven't really had the time to figure out how to do that yet.
Old Nov 20, 2003 | 04:23 PM
jesseenglish
Here's some tech info on my WB O2.
http://www.wbo2.com/2a0/2a0info.htm
And here's the support site for the setup, which the manufacturer is always on to answer questions. It's a small business so there's only a couple guys that run it, but they know their ****.
http://autos.groups.yahoo.com/group/...yguid=92081475
Old Nov 20, 2003 | 04:33 PM
G3po's Avatar
G3po
Default wide band sensor
Anybody ahve experience with this unit?
http://www.widebando2.com/Product%20Info_1.htm#monitor
With just one sensor , which side on the VQ seems best for the bung. A few destroyed #6s , so maybe that bank is safest?
Old Nov 20, 2003 | 04:36 PM
jeffw's Avatar
jeffw
Approximately how many miles can you put on your car before the wideband 02 goes bad?
Jeff
Old Nov 20, 2003 | 04:43 PM
jesseenglish
Default Re: wide band sensor
Mine is installed in the DS bank simply for ease of installation.
Mucho expensive and it doesn't log anything, but AFR and RPM and you have to purchase the sensor separately.
Generally most WBO2 sensors use a super expensive sensor, that is hard to get. I can't remember the part number off the top of my head. Usually anywhere from $150 - $200
The Techedge unit uses the wideband O2 that comes from the VW 1.8T engine. You can pick them up at any VW/Audi dealership for $40 or less.
I think the complete Techedge setup is around $350 depending on the strength of the Australian dollar when you order it.
WB O2 sensors will have the same life as normal O2 sensors as long as you use unleaded gas, which isn't a problem for us.
Old Nov 20, 2003 | 04:50 PM
jawbone's Avatar
jawbone
Just don't drop your 02 sensor.. they are kinda fragile. And always anti-seize the threads of the sensor or it will NEVER come out..
Old Nov 20, 2003 | 04:52 PM
GaryK's Avatar
GaryK
I'm currently using an LM-1 from Innovate Motorsports. Its a nice unit, with datalogging capability and the potential for several auxillary inputs for logging. I do have to say this is a fairly new unit to come to market, and is not as proven as others at this time. Read about it here: link
Old Nov 20, 2003 | 04:53 PM
jesseenglish
Ah yes, anti seize. Do yourself a favor and heed jawbones advice.
Old Nov 20, 2003 | 04:56 PM
jesseenglish
I've heard good things about the LM-1. A nice thing is it has onboard logging storage, mine doesn't. The new rev3 version of the techedge unit will.
The only reason I didn't get the LM-1 was because it seems to be more of a temporary installation setup. I wanted mine permanently mounted with an external gauge.
Old Nov 20, 2003 | 04:57 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Jesse: Remember the A/F gauge you posted a pic of before. Was that just a gauge that you buy in addition to the full wide band O2 sensor or was that an all inclusive kit?
In other words, can you buy that gauge and hook it up to the same kit you have or does it have it's own "kit"?
This is the one:
Old Nov 20, 2003 | 04:58 PM
jesseenglish
There's a guy doing a group buy on the LM-1 on automotive forums I think. If enough people are interested, I'm sure that you guys could set up a group buy of your own.
Old Nov 20, 2003 | 05:01 PM
jesseenglish
That gauge was originally designed for a NB O2 sensor. However I have purchased one of those gauges and sent it off to techedge. They're doing some reverse engineering right now, so that the TechEdge unit can use that gauge. In return I'm getting an additional WBO2 unit from them for free so I can monitor both banks of cylinders.
Old Nov 20, 2003 | 05:05 PM
GaryK's Avatar
GaryK
You can permanently mount the lm-1 box if you want...its not as small as others, but it can be dealt with. It will also allow for a remote display, and with the latest firmware it will log directly to a pc via serial port from what I understand. The internal logging feature is nice though, I actually would rather not have the laptop in the car.
Old Nov 20, 2003 | 06:56 PM
MY350Z.COM's Avatar
I'm waiting for AEM's 52mm A/F ratio gauge w/ built in wideband. Just 1 little gauge contains everything required for it to read wideband. No need for external circuit boards or anything.
It will also be cheaper than most WBO2's out and should be out before the end of the year.
Old Nov 20, 2003 | 07:03 PM
jesseenglish
Wow, that will be cool, They must have really done some serious miniaturization, because it takes a lot of circuitry to control a wideband sensor.
Old Nov 20, 2003 | 07:06 PM
MY350Z.COM's Avatar
exactly what I thought. It was shown @ SEMA. It'll be out in Dec.
Old Nov 21, 2003 | 03:31 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Vic: Can you keep me posted on this? I would be interested in this. Thanks.
Old Nov 21, 2003 | 07:44 AM
MSGarrett1's Avatar
MSGarrett1
Thanks for all the links and info.
Old Nov 21, 2003 | 07:48 AM
jesseenglish
Hey, did you happen to notice if it was capable of any logging? If so, I'd consider switching for a smaller unit like that.
