airflow sensor? help please
Old Dec 14, 2010 | 08:44 AM
jcer's Avatar
jcer
Default airflow sensor? help please
-Check engine light-
Check engine llight-air flow sensor for my intake is reading hot air to engine??
If I buy a injen or nismo intake will that fix my problem? any help would be great thank you!
Jesse c
2003
Old Dec 14, 2010 | 09:02 AM
DavesZ#3's Avatar
DavesZ#3
What is the actual DTC code you are getting?
And no, there is no code for "hot air" getting to the engine so there is no need for a CAI. The stock air box takes its air from behind the bumper in front of the radiator. It works quite well, even when compared to a true CAI.
Old Dec 14, 2010 | 09:06 AM
ksmoore's Avatar
ksmoore
how is the car running in terms of the rpm band?
hesistation? lagging? normal?
usually its something small like a loose wire or a dirty maf, but those small things can lead into a bigger problem, i have a spare laying around
Old Dec 14, 2010 | 12:07 PM
jcer's Avatar
jcer
it runs perfect ?
I was thinking its the hook up sensor near the stock air tank filter because
the wire's are in bad shape but there is not enough wire to re-wire so
how do you guys think I can fix this? Thanks again
Old Dec 15, 2010 | 05:32 AM
rcdash's Avatar
rcdash
Respond to the post by DavesZ#3, then maybe someone could help you.
Old Dec 15, 2010 | 09:41 AM
DavesZ#3's Avatar
DavesZ#3
Originally Posted by jcer
it runs perfect ?
Get a scan tool or an OBDII monitor and you can read the intake air temperature from the MAF sensor.
You still haven't clarified our confusion over the check engine light. What code are you getting? Without that, there's no telling what problem you have.
Old Dec 15, 2010 | 12:23 PM
terrasmak's Avatar
Do you have an aftermarket intake on the car now?
liqalu04
Jan 2, 2022 12:58 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
350Z Project X
Oct 17, 2015 05:16 PM
