Help Removing the Radiator..
Old Dec 29, 2010 | 10:16 AM
cityslick43's Avatar
cityslick43
Default Help Removing the Radiator..
Hello everyone, I have a 2005 enthusuast and I havent driven my car for about 3 weeks and its really killing me on the inside! It overheats and I found the cause, I need to take the radiator out but I really dont know how, is there any advice or a diagram that can help me do this. Its my only day off and really wanna get this done today. Do i need to drain coolant? drain radiator? and how? any advice would be nice, i just need to pull radiator out
Old Dec 29, 2010 | 10:43 AM
VO...'s Avatar
VO...
Administrator
Moved...
Old Dec 29, 2010 | 11:21 AM
cityslick43
I'm sorry im not good with forums I just really need help.
Old Dec 29, 2010 | 11:25 AM
winchman's Avatar
winchman
You'll need to drain the coolant before disconnecting the hoses unless you don't mind making a big mess. Dumping antifreeze is bad, since it's poisonous to plants and animals.
Get a copy of the service manual to get the procedure for taking the radiator out. You'll definitely need it for putting everything back together and getting ALL the air out of the system.
Old Dec 29, 2010 | 02:51 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Do a search and it will help you.....geez.
Old Dec 29, 2010 | 08:33 PM
MDK's Avatar
MDK
Taking out the radiator is a ton of work. Are you sure you need to do this?
The drain plug is on the bottom of the radiator, pretty much right under the fill cap. Be sure you have something to catch the 9.5 qts that will come out.
Old Dec 29, 2010 | 08:42 PM
WTFMike's Avatar
WTFMike
Did you really have to ask if you need to drain the radiator to remove it? I feel like that is pretty much common knowledge.
Old Dec 30, 2010 | 09:02 AM
cityslick43
I already did it and the car is working again thanks everyone, I removed it myself with a diagram
Old Jan 1, 2011 | 01:05 AM
terrasmak's Avatar
If a radiator is a ton of work, i would hate to know what you consider a a simple job.
Old Jan 2, 2011 | 09:12 AM
cityslick43
Hello everyone, My car is overheating, when I take it on the road in about 1 minute the c/h gauge seems to elevate and another minute the car is overheating. I never drive when the temp is all the way up. I took it to a dealership for a diagnostics check and they said leak in radiator and a bent coolant pipe, they bent the pipe back as far as they could. I changed the radiator, (brand new) and put new coolant, and put a brand new thermostat in the car. After all of this work the car is still overheating and there are no leaks! The fans both spin and Im not getting heat in the cabin. Dealer said its not head gasket, so what is left, what can I do? Help please, I really wanna drive my car!
Old Jan 2, 2011 | 10:46 AM
plumpzz's Avatar
plumpzz
you have air in the lines still. You need to purge out the air. Lift the rear of the car, massage out some air using the techniques in the service manual. Theres also a no air filler that'll let you fill the radiator without air.
Old Jan 2, 2011 | 10:48 AM
cityslick43
How can I do this from the back of the car? So can air really be that big of a factor?
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Cashwin
Oct 1, 2015 06:36 AM
