Depinning the MAF sensor
Old Jan 9, 2011 | 09:05 AM
Andrei's Avatar
Andrei
Default Depinning the MAF sensor
Anyone here know how it's done? I took out the locking clip inside the harness but I still cant get the wires to unplug? How does it unplug?
Old Mar 28, 2011 | 01:24 PM
08sleeperz's Avatar
08sleeperz
I am in the process of doing the same thing cus one of the wires has a crack/split in the casing and wanna splice a new wire in place. I had the unfortunate experience of having to de-pin my injector clips on my Si and lets just say its not the easiest thing to do. Basically once you get the locking clip off you need to find something small like a sewing needle or possibly a small flat blade screwdriver. You then insert it into one of the slots and you pretty much have to apply a "scooping" motion to unhook the clip. Its a little hard to explain but once you get it, you'll understand. Basically you're trying to push the clip down and out and then it will pull out of the back of the whole MAF clip. Hope this helps a little...good luck.
Check out this write-up and video. Its the same concept for the maf clip (any clip really). And don't forget to disconnect the battery and drain the power before trying this cus you can do some serious damage.
http://www.8thcivic.com/forums/do-yo...r-install.html
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
