Megan Headers question??
Old Jan 14, 2011 | 08:52 AM
NissanUnlimited's Avatar
NissanUnlimited
Vendor - Former Vendor
Exclamation Megan Headers question??
Hey guys, i have a set of Megan headers but main questions are:
Does or Has anyone ever installed the Megan Headers into 350z/g35 2 or 4 doors?
If so, are the a simple straight bolt on or did you have to make modifications to it??
I had a customer come in here that bought a steering column pivot arm link, who he claimed that he had a problem installing the Megan headers in his 06 Z. He said when he Turned left to right the Pivot arm hit the header on the driver side.
Anyone know if this is true or not from previous experience..??
Old Jan 14, 2011 | 09:01 AM
bimmertech's Avatar
bimmertech
i can't comment specifically on the megans, but in 06 the steering rack design was changed and it is very common place to have header fitment issues because of that. like your cust stated, it is the slip joint that connects the shaft to the rack that rubs on the header.
you can try to move the slip joint up or down and that may gain you the clearance needed. if that does not work try grinding on the joint or changing the orientation of it.
my stillens rubbed badly under hard turns while accelerating--mainly at the track. it would rub so badly the steering wheel would lock until i let off the throttle.
Old Jan 14, 2011 | 09:48 AM
NissanUnlimited
Yea, he said he had 2 grind off a piece of the bolt but i was thinking the shop who did his work had slipped off the joint and when they installed it wasn't pushed down all the way.. He mentioned they DID have to slip it off..
but thanks for the quick response.. I'm trying to put a set of Megan's on an 06 g35 4dr a/t!
Old Jan 14, 2011 | 09:56 AM
Mark the steering linkage. Remove the knuckle. Install headers. Install knuckle And align marks. Members have been doing this for 8 years.
Old Jan 14, 2011 | 11:06 AM
NissanUnlimited
So my quest now begins.. i'll post some pix and info on how this goes! Is there anything else i need or should be upon Header installation?? Probably gonna buy the header wrap..
Old Jan 20, 2011 | 06:10 AM
T3K_V35's Avatar
T3K_V35
nooooo, not wrap......look up caswell plating, they have a d.i.y. ceramic coating for headers and exhaust. Great stuff, used it on my G. LOVE IT!!!
Old Jan 20, 2011 | 08:24 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
u guys have a dyno?
Old Jan 21, 2011 | 04:21 PM
e30cabrio's Avatar
e30cabrio
I jet hotted mine and they went in no problem (with the steering knuckle) big pita as Nissan had attached the OEMs with a gun when they replaced my original oil consumer.
Old Jan 21, 2011 | 06:21 PM
2004Black350z
Exhaust Whore
why did u get rid of them?
Old Jan 21, 2011 | 06:32 PM
e30cabrio's Avatar
e30cabrio
I didn't, the engine was replaced by Nissan and when they installed it they installed teh oem exhaust manifolds with the gun so the bolts were freaking tight.
http://s20.photobucket.com/albums/b2...IMG_0040-1.mp4
This is the only video I have of the car. This is with a "silencer"
Old Jan 21, 2011 | 06:36 PM
2004Black350z
Exhaust Whore
dam that sounds so high pitched. mine is deeper. Wonder if thats cause the silencer or ART and XYZ
Old Jan 21, 2011 | 06:37 PM
e30cabrio's Avatar
e30cabrio
Silencer is out, it is louder. It stole 30hp.
Old Jan 21, 2011 | 06:41 PM
2004Black350z
Exhaust Whore
im lost. reiterate please lol
Old Jan 21, 2011 | 06:42 PM
e30cabrio's Avatar
e30cabrio
That was the first run, with the silencer. I removed it and the car got louder and just removing the silencer gave 30hp.
Old Jan 21, 2011 | 06:44 PM
2004Black350z
Exhaust Whore
holy ****. u dynoed 290? thats impressive. Dang i wish u would have a vid of WOT or the next dyno session with silencer out
e30cabrio's Avatar
e30cabrio
Middle of the runs while he was tuning the cams.
I thought I had a second battery, the one I had died after that.
271/264 was the max. Stroker is in the works.
Old Apr 27, 2011 | 01:53 PM
mgrotel's Avatar
mgrotel
so does this mean i might have fitment issues on my 06 g35 coupe? or were the steering components different in the g?
Old Apr 27, 2011 | 02:38 PM
e30cabrio's Avatar
e30cabrio
My 06 has no fitment issues at all.
Old Apr 27, 2011 | 04:05 PM
mgrotel's Avatar
mgrotel
Great, thanks. Which headers do you have?
Old Apr 27, 2011 | 04:18 PM
e30cabrio's Avatar
e30cabrio
Stainless short Megans, jet hotted.
