valve spring rev limits
Old Jan 15, 2011 | 07:50 PM
the_coupe's Avatar
the_coupe
Default valve spring rev limits
search didnt pull up much but i was curious as to what valve springs were good for what RPMs??
i have BC stage2 cams with their valve springs and ti retainers on order along with manley rods and cp pistons to follow. the bottom end will all be balanced....from the crank pulley to the comp clutch. so i was curious as to who is running BC valvetrain and what RPMs they are running at safely.
Old Jan 15, 2011 | 08:12 PM
Andrei's Avatar
Andrei
Bump it up to 8250 with a Cosworth plenum.
Old Jan 16, 2011 | 06:01 PM
meatbag's Avatar
meatbag
Oil pump will let go before you max out the valve springs.
Old Jan 16, 2011 | 06:22 PM
the_coupe's Avatar
the_coupe
will be puttin a new revup pump on. i was just curious as to who has pushed these. i'll tune to 8k but thinkin ill end up shiftin between 7000-7500....depends on powerband
Old Jan 16, 2011 | 06:51 PM
meatbag's Avatar
meatbag
If its a street car and doesn't see high RPM that much you will be fine. But anything with power over 7500 for extended periods is asking for a blown up oil pump.
Rev_Night
Nov 7, 2020 06:00 PM
