Combustion chamber volume?
Old Feb 1, 2011 | 06:42 AM
jmccarty's Avatar
jmccarty
Default Combustion chamber volume?
Combustion chamber volume 58.5cc (OE approx 56 cc) measured?
http://www.cosworth.com/Default.aspx?id=1105747
Is the VQ35 a 3.36 or a 3.5 litre engine?
Anyone have any other qualified measurements?
Old Feb 1, 2011 | 08:29 AM
ocdz's Avatar
ocdz
pretty much every place I've looked sites displacement as 3498cc.
Check this out though:
https://my350z.com/forum/engine-and-...e-know-it.html
Also did my own math... I'm not sure if it's all correct but:
95.5mm Bore, 81.4mm Stroke
95.5/2= 47.75mm radius
47.75^2*pi= 7163.0215mm piston area
7163.0215*81.4mm= 583069.9501/1000=583.07cc per cylinder
583.07*6=3498.42cc OR 3.5L roughly
not sure if it's right but it makes sense to me
Also got me thinking that combustion chamber volume may measure the engine at it's minimum volume vs. displacement being maximum volume. the ratio between these is where compression ratio comes into play.
m_0g
Jun 3, 2021 10:05 AM
350Z Project X
Oct 17, 2015 05:16 PM
matt@importlife.tv
Aug 29, 2002 05:11 AM
