VDC/SLIP/ABS - HeadLight problem
Old Feb 8, 2011 | 07:10 PM
Biggs_02's Avatar
Biggs_02
Default VDC/SLIP/ABS - HeadLight problem
I got a 03 Performance Edition 350z with a weird problem going on right now. The car came with HID headlights. One day I was driving and I turned on my headlights and out of nowhere VDC/SLIP/ABS light all came on. When I turned off the headlights, the ABS light turns off and the VDC/SLIP was still on. I had to turn the car off and the VDC/SLIP light would turn off. Same thing happens everytime. Then I noticed that when I press the brake pedal, the headlight, the orange strip, turned on!! Very werid. Also when my headlights were on the brake light on the tail light were also on. I then pressed the brake switch ( on the brake pedal) a few times and the problem went away, well...half the problem. Now the brakes are fine, but my VDC/SLIP are always on. It does not reset itself and the VDC switch does nothing to help. Any help would be appreciated.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
