coolant bypass ( problem welding )
Old Feb 12, 2011 | 06:33 PM
856_reilly's Avatar
856_reilly
Default coolant bypass ( problem welding )
Ok so I deleated all the ports that were in the write up... I'm having major issues with pin hole leaks. I read most of the thread and I still am gonna ask if anyone has some good advice on sealing these up. Also any suggestiond on makeing sure the slag is compleatly out on the in side? Any help would be great..... Thanks guys
Old Feb 12, 2011 | 11:33 PM
winchman's Avatar
winchman
What thread are you referring to? Link?
Old Feb 13, 2011 | 10:44 AM
spent's Avatar
spent
I don't think you're going to be getting the slag out on the inside unless you cut the pipe then reweld it. It's alsmot impossible to get to some of those outlets... As for leaks, I welded up the coolant pipe and haven't had any problems... ? dunno
Old Feb 13, 2011 | 02:03 PM
856_reilly's Avatar
856_reilly
Ya must have gotten lucky!!!!!!! I'm having nothing but PROBLEMS.... I had 4 people and no luck...Now I just had someone tell me to tig weld it so I'm going to give that a shot I'm just concerned bout whats inside the pipe now. There was 2 times where there was holes that blew threw the metal...
Old Feb 13, 2011 | 04:02 PM
spent's Avatar
spent
How exactly are you going about filling the holes?
Old Feb 13, 2011 | 05:17 PM
856_reilly's Avatar
856_reilly
Pluging them with like nuts.. Welding them in then cutting them down. The welder just keeps putting little pin holes in the metal.
Old Feb 13, 2011 | 10:29 PM
winchman's Avatar
winchman
Sounds to like you're not getting the part clean. You might also want to try back-gassing, which puts inert gas on the inside of the pipe to stop oxidation of the heated metal that's not being protected by the gas from the torch.
Are you using TIG or MIG? Maybe it would be easier to braze it using oxy-acetylene.
I'm assuming the part is steel, since you mentioned using nuts to fill the holes.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
